How you take out the rear seat???
Old Nov 19, 2002 | 12:32 PM
MyMax92's Avatar
Hey guyz, well my friend is a retard, my outside lock for my trunk never worked since i bought the car, but one day my friend decides to be a know it all and flips the latch inside the trunk that disengages the cable to the trunk popper, so now i cant get my trunk open. Now,i need to get that rear bench seat out so i can try and crawl through or get something in that trunk to swich he latch again...anyone know how that rear bench comes out??
Old Nov 19, 2002 | 12:43 PM
nubiannupe's Avatar
OG Maxima.org Member
Look here for the answer you seek, grasshopper!
(don't worry, I'm not sending you to the search pages...)
Old Nov 19, 2002 | 12:46 PM
lophix's Avatar
lol grasshopper. lol
Old Nov 19, 2002 | 01:36 PM
MyMax92's Avatar
lol, yea thanx i got the instructons but now the only thingis the dam clips on the lower seat won't come up...i yanked real hard, even pops gave it a try....now they r a lil lose, but no dice on gettin' them to pop off....
Matt93SE's Avatar
STFU n00b!
when you get the trunk open, spray some penetrating oil in the lock and work on it with the key. the problem is that the parts inside the lock have rusted together due to non-use.
once you get it working again, spray it out with soem brake cleaner to remove the solvents, then let it dry for a while and spray some graphite lube in it and you're set for another 10 years.
it took me 5-15 minutes on each one, but I've been able to free up every lock this has happened to (so far, 4 maximas and a couple of other cars).
Old Nov 19, 2002 | 01:44 PM
MyMax92's Avatar
Alrite, thanx, ill try that....just once i get the dam trunk open!
Old Nov 20, 2002 | 09:19 AM
Lordrandall's Avatar
Use a really big Flat head screwdriver. Be careful not to damage your seats, put pry up slowly and they will come off no problem.
Old Nov 20, 2002 | 08:53 PM
MyMax92's Avatar
Got the bench out, fixed the trunk and fixed the lock sucessfully, thanx for the help!
Old Nov 21, 2002 | 08:20 AM
Freaknificent's Avatar
this works on the doors also?
i've noticed that my key is a lil hard to turn at times i kinda have to wiggle it back and forth.
so i just spray it inside the lock where the key goes? not problems should occur from this right?
Old Nov 21, 2002 | 02:52 PM
That is correct. Just avoid using WD40 if you can. A little graphite will do the job better.
matts95max
Apr 23, 2025 10:44 AM
AcuraLegend
Oct 17, 2016 08:47 PM
doctorpullit
Sep 10, 2015 06:33 PM
ef9
Sep 5, 2015 11:18 PM
