Knocking sound. Suspension? please help
Old Nov 21, 2002 | 10:58 AM
dancer
This isn't an engine related sound. It occurs when I drive over bumps, and now and then it occurs when I put a load on the engine. It seems to be coming from the left front. At first I thought it was coming from my FSTB (the FSTB made some knocking/creaking sounds until I oiled the two pivot points). I've recently replaced the front wheel bearings but I've never replaced the tie rod ends, control arm bushings or steering rack. Any suggestions?
Old Nov 21, 2002 | 11:13 AM
lophix's Avatar
Re: Knocking sound. Suspension? please help
could be struts. ever replaced your rack and pinion?
Old Nov 21, 2002 | 11:31 AM
RosenKen's Avatar
Re: Re: Knocking sound. Suspension? please help
Um, steering rack = rack & pinion. So no.
Old Nov 21, 2002 | 11:56 AM
lophix's Avatar
Re: Re: Re: Knocking sound. Suspension? please help
true.
Old Nov 21, 2002 | 12:03 PM
5spd92SE's Avatar
I would focus on 3 areas:
1. The work that you recently performed (check it all over)
2. Motor mounts
3. Ball joints
Old Nov 21, 2002 | 12:13 PM
dancer
2. Motor mounts
3. Ball joints
I did have the struts replaced about a year ago. I'll check my work, then look at the motor mounts and ball joints. Thanks.
user 11122324
42
Jul 18, 2022 03:35 PM
Apr 16, 2020 05:15 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
