Removing Cam Sprockets
Old Nov 25, 2002 | 08:08 PM
surfermax92's Avatar
I just got the crank pulley and timing belt off of my vg33e, and now I have to take the cam sprockets off. When I try to loosen the bolt on the sprocket, everything moves. I'm afraid of turning the sprocket, but I see no way to secure it. I have a 91 vg30e fsm, and it shows some tool fitting just after the bolt. The 33e sprocket has no place for such a tool to go. Does anyone have an idea of how to loosen the bolt, or will I just have to go spring for a vg33e manual? Any ideas would be appreciated.
Old Nov 25, 2002 | 11:20 PM
Jeff92se's Avatar
I'm needing a caw
On the VE, you put a big arsed wrench on the cam(there is an indentation for it)But if you are fooling w/ a Nissan engine w/o a Nissan FSM, shame on you.
Old Nov 25, 2002 | 11:52 PM
Nismo87SE's Avatar
Re: Removing Cam Sprockets
Behind the cam sprocket there should be a place to fit a wrench to. When I did the cam swap in my se-r, I needed a 1in open end wrench to hold the cam in place. IIRC I used vice grips on my VG, so you can use either a cresent/open end wrench or vise grip on this part. If you look at the cam in this area, 2 sides should be near flat.
Old Nov 26, 2002 | 03:04 PM
Jeff- I thought the vg30e would be close enough
So I should take the rocker cover off and actually clamp onto the cam?
I really need to get these off to send them to Morgan
Thanks for the quick help guys
Miles
my03maxima
Jul 28, 2024 07:40 AM
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
