crazy tach at low speed -->new car?
Old Dec 6, 2002 | 08:59 AM
hclll's Avatar
My max has a problem at very low speed (<5mph)or when stops at a light. The tachometer could jump between 1100rpm down to 400rpm and the whole car is shaking! I am afaid it will expire some time! THis only happens when gas pedal is not presssed. Once I step on the gas, every thing looks fine. I also have a check list, pleas pick what you think it is most likely:
1. idle speed setting messed up. ( Please tell me how to reset.)
2. The rubber pipe between air filter box and intake manifold is cracked.
3. Bad sensor?
4. EGR/PCV valve?
This problem has been so annoying that I want to trade it in for a new Acura TL if prob not fixed. Which gen of max do you think is comparable to 2003 TL performance-wise?
Old Dec 6, 2002 | 09:34 AM
mtcookson's Avatar
i would check the pcv. mine is bad and does that but i'm too lazy to go get it and fix it. it's only like 2 dollars at autozone.
Old Dec 6, 2002 | 08:23 PM
eric93SE's Avatar
Re: crazy tach at low speed -->new car?
3. Bad sensor?
4. EGR/PCV valve?
I had a broken/missing shift cable bushing and it caused similar symtoms, the idle would jump around when my foot was off the gas and the idle would race when I was at a stop. There are two of them, ones located at the tranny where the cable meets the tranny, and there is another that is above the catalytic convertor a heat sheild needs to be removed in order to get at it.
Old Dec 7, 2002 | 07:56 AM
ChrisCheezer's Avatar
***2. The rubber pipe between air filter box and intake manifold is cracked.***
- if that crack lets air into the car ... it should stall-out.. GET A CAI now..
Old Dec 9, 2002 | 07:43 AM
hclll's Avatar
Eric, could you give a little detail
about where the bushings are and how to fix them?
Old Dec 9, 2002 | 08:04 AM
eric93SE's Avatar
Re: Eric, could you give a little detail
do an org search for shifter bushing
http://forums.maxima.org/showthread....=shift+bushing
Old Dec 9, 2002 | 11:56 AM
Brandon90gxe's Avatar
its probably a vacume hose leak, i have a minor version of that rightnow too.. i gota fix it
Lakersallday24
Jun 16, 2019 01:35 AM
schmellyfart
Sep 25, 2015 04:47 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
maximaham
Aug 7, 2015 01:11 PM
RealityCheck
Aug 5, 2015 06:18 AM
