Idle control screw??
Is there any other way to adjust the idle speed of the car? I got the check eng. light a few days ago and turns out my CHTS whent out, but after i put the computer back to "normal" my idle speed sucks, and sometimes stalls it. But once i run it for a bit it clears up. But every time i get in the car after its been sitting, it stalls. Is the ECU still in some mode or is there another screw i can adjust to compensate.
Originally posted by surfermax92
The idle control screw is under a black cap on the idle air control valve which is located on the front right side of the vg's upper intake manifold. I really can't help you with the ECU question though.
I adjusted my idle at the throttle when it was idling low, just had to play with it a bit because at a certain point it just started to walk away on me
Originally posted by Taegost
How does it effect idle? Clark showed me that, and I cranked it up, but it didn't effect my idle at all, just cause it to suck in more air... Dropped my gas mileage a little bit and gave me a bit more power, that's it.
TKHanson
Nov 24, 2018 01:39 AM
Unclejunebug
Apr 2, 2016 05:42 AM
tseng1023
Oct 15, 2015 08:30 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
