Hi,
I am fast approaching the time where I have to do something about the front end on my 91 max. Do I need to remove the axle for the control arm replacement? Ball joint replacement? CV replacement? Also, don't I need to have special tools (for removing the snap ring(s)) to do this work? Is this within the relam (sp) of a weekend mechanic?
Any help is appreciated.
Stephen
Stephen
Quote:
Originally posted by arges
Hi,
Stephen
Hi,
Stephen
you might want to:
1. get a chiltons or haynes
2. search a lil bit if it already has been discussed
3. DEFINITELY ask Matt93se. He is offering help on the issue of control arms that will save you from buying the special tools and removing and replacing the bushings which from what i gathered is a real pain.
ball joints, axles, and control arms can all be replaced with regular hand tools.. it's working on the parts themselves that require special tools.
only real problem you'll have is getting the control arms off the car. the front bushings sometimes siezes to the shaft, and it'll require some liquid wrench and a pulley puller to get it off. otherwise, that's the only special tool you'll need. search for instructions on how to do them all.
Quote:
Originally posted by Laly
an impact wrench will make the job go alot faster
makes it go a lot faster, but not required... can't wait until I get my air compressor for christmas. Then I'll be able to use all the tools I got for christmas LAST year! Originally posted by Laly
You've used them already.
Quote:
Why don't you go install Altezzas on your 4th gen?Originally posted by bill99gxe
They've been packed up since I moved out last june.. just after I used them on YOUR car. Butthead. Originally posted by bill99gxe
