Installing Side Markers
Old Jan 2, 2001 | 01:29 AM
ngthing's Avatar
Is there anything I should know? I drill a hole in the side..then what?
Old Jan 2, 2001 | 05:54 AM
DanNY's Avatar
Ad·min·is·tra·tor
then wire it up.
Old Jan 2, 2001 | 07:27 AM
ngthing's Avatar
Originally posted by DanNY
then wire it up.
do I need any inline fuse? how do I attach the marker to my car?
Old Jan 2, 2001 | 07:28 AM
MaximaRacer's Avatar
installing side markers is easy..first you need to drill a whole the size of a nickle on your fender and then tap the wires from the side markers to the wires of your signals
Old Jan 2, 2001 | 07:31 AM
DanNY's Avatar
Ad·min·is·tra·tor
you should be ok w/o a fuse if your only tapping the blinkers. just make sure you loom the wire so it's semi protected. i assume the bulb in the corner is a 194 bulb.
then wire it up.
ngthing's Avatar
why would I need to drill a hole in my fender?
Old Jan 2, 2001 | 07:34 AM
DanNY's Avatar
Ad·min·is·tra·tor
wait a sec...did u do any resarch b4 u buy something or think about buying it?
the side marker mounts on the side of the fender. you'll NEED to drill/cut a hole on the side of the fender to mount it.
Old Jan 2, 2001 | 07:38 AM
ngthing's Avatar
okay, I am kind of stupid with cars when it comes down to ACUTaL wiring ;p
would it be hard to make the sidemarker always on, and hen blink when I signal?
would these be the size I'm lookin for?
http://cgi.ebay.com/ebaymotors/aw-cg...640272&r=0&t=0
a shop here wanted 50$ to install + marker costs, I figured that was a bit pricy
Old Jan 2, 2001 | 07:40 AM
ngthing's Avatar
I'm gathering info now . looking at my sig pic, up and right of the front wheel is where I mount it right? is it hard to drill there?
Old Jan 2, 2001 | 07:46 AM
DanNY's Avatar
Ad·min·is·tra·tor
if your not familar to drilling to sheet metal you might end up needing a new fender. measure twice and cut once. once you cut it there's no turning back. best bet is to center punch it and then drill a hole..at least for the wires. on the ebay bid it states that you need to drill a hole in the fender.
well side markers are there to blink when you signal and not on all the time. but if u want to do that then you would have to figure it out. i know how to do it but i'm afraid if i told u how that you'll mess up. you would prob tap one wire from the blinker (in bumper) and the wire to the corner lense.
Old Jan 2, 2001 | 07:58 AM
ngthing's Avatar
the newer cars have the side markers dim, and when you signal the blink. i will see what I can come up with..
Old Jan 2, 2001 | 08:00 AM
DanNY's Avatar
Ad·min·is·tra·tor
that's what i'm afraid of.
Old Jan 2, 2001 | 08:08 AM
ngthing's Avatar
and that is...?
Old Jan 2, 2001 | 08:30 AM
DanNY's Avatar
Ad·min·is·tra·tor
what you can come up with.
and that is...?
Old Jan 2, 2001 | 08:41 AM
ngthing's Avatar
and that is...?
thanks for the words of encourgament.
Old Jan 2, 2001 | 08:48 AM
DanNY's Avatar
Ad·min·is·tra·tor
yup anytime!
and that is...?
Old Jan 2, 2001 | 08:53 AM
block's Avatar
50 bucks isnt even bad for an install price. I know a kid here that paid 250 bucks to have some put on his civic. I would recommend letting them install it.
JRod28
Dec 29, 2023 09:56 PM
vingodine
45
May 21, 2016 12:46 PM
95Maxi
35
Sep 2, 2015 10:37 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
papo99
Aug 9, 2015 07:32 AM
