Anyone install air horns on their 3rd gen?
Old Jan 2, 2001 | 01:30 AM
ngthing's Avatar
Anyone install air horns on their 3rd gen? I bought my air horn set, and I'm looking for instructions on installing the horns. I can't locate teh stock horn, and I am not sure which wires I should cut.
Old Jan 2, 2001 | 05:55 AM
DanNY's Avatar
Ad·min·is·tra·tor
the stock horns are right behind the front bumper/grill area. did your horns come with instructions?
Old Jan 2, 2001 | 09:28 AM
Cincy94Max's Avatar
after a quick little search...
After searching for "air horn" I found 76 threads. Anyways I found a link in one of them. http://integra.vtec.net/geeser/megamax/horns.html
Old Jan 2, 2001 | 09:30 AM
1FasMax
hey how much are these air horns, what make and model number should I get, I can we get instructions on how to install them Matt
Old Jan 2, 2001 | 09:53 AM
Matt93SE's Avatar
STFU n00b!
IMO, airhorns make our Max sound like a clown car. but whatever floats your boat.
the horns on our car are located on the center support bracket right behind the grille.. they're about 2.5" round.
the rest of the instructions should come with the horns.. if you can't figure it out from there, you probably shouldn't be trying to install it yourself. (no offense intended, but they're a pretty simple job)
Old Jan 2, 2001 | 02:10 PM
ngthing's Avatar
I think I paid $25.00 shipped, dunno from where though
Old Jan 2, 2001 | 02:12 PM
ngthing's Avatar
They do sound like clown cars! The horns are REALLY annoying though, I figure it is $25.00, if it helps prevent an accident one day, it will be well worth it. It is not like I'm going to be laying on the horn 24/7, but if I need to use them, as tehy were intended to be used for, I'd like them to catch somebodies attention.
Thanks for the info, I'm not great with cars, but I want to find out what the job entails before I take it on, my uncle will be helping me, and he's done everything to his s/ced Mustang. I think I am in good hands, with him and you guys at my side
Old Jan 2, 2001 | 05:40 PM
ray89se's Avatar
air horns
i hope there Hella at least..... so hear we go.... u should have a relay supplies with ur set.... look at the relay at the terminals... u will see 85 86 87 30.... u will be connecting wires to them also the connections on the air horn should show "+" and "-" ok from ur factory horn wire..tap another wire to it on the other end of the wire gets connected to 85 of the relay terminal u must use wire crimps or soldier it..... now with another wire connect one side to 86 and the other side to ground of the car pls u a ring terminal....the next wire the one side u connect to 87 terminal and the other side u connect to a fuse holder and place a 20 amp fuse u connect straight to the battery... now with another wire u connect the one side to terminal 30 the other side of that wire goes to the air horns "+" ternimal... u ground the "-" terminal and there u go i think the hoses self explanitory how u connect it to the chasis make brakets or use zip ties... it very easy just take ur time
items need
wire crimper/stripper
4 speaker terminals blue
about 6 feet of 12 ga wire
2 ring terminals blue
a fuse holder
2 blue butt connectors
20 amp fuse glass or the red one (depends on the fuse holder u get)
honk that horn and ur all done
the average life span on a air horn is like 1 1/2 yrs
depends if ur horn happy too
Old Jan 2, 2001 | 07:20 PM
FAST4EN's Avatar
Re: air horns
Mine only lasted about 3 months... (the first set)
The second set was a different brand and lasted a little longer, the 3rd set only lasted about 2 weeks because then my 90SE got totaled....I should put some on my Z for ****z and giggles.
Old Jan 2, 2001 | 08:19 PM
UNEEK 1
I have the Hella air horns but I don't use them for my reg. horn I use it for my second security alarm and boy when it goes off u don't have 2 worry about people acting like they don't hear ur sh@t going off. That's fo sho.
stevesmax
Dec 17, 2020 11:57 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
kirkhilles
Aug 8, 2015 10:53 AM
ViciousVQ30
Aug 5, 2015 05:40 PM
