How to remove headlamp????
Old Jan 7, 2003 | 07:13 PM
sratay's Avatar
I have a 1993 Maxima that the driver's side headlamp took a direct hit with a rock and busted it pretty good. I was able to buy a used headlamp assembly but have no idea on how to change it. I have the service manual but see no mechanical schematic for the headlamp assembly. Any help on this would be appreciated. Thanks in advance!
Steve in Iowa
Old Jan 7, 2003 | 07:51 PM
«§»Craig B«§»'s Avatar
remove corner light (one screw on top and it pops outward)
remove 2 10mm bolts/screws on outside that are exposed after removing corner
remove 2 10mm nuts taht are on the backside of the headlight frame close to the radiator
remove 2 clips holding headlight bracket to grille
that should be it
search for more detailed info if you need it; I've seen it posted here before
good luck
Old Jan 9, 2003 | 02:39 PM
sratay's Avatar
that should be it
good luck
my03maxima
Jul 28, 2024 07:40 AM
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
