Nissans Poor material choices
Old Jan 21, 2003 | 01:01 PM
ocMax's Avatar
Ok i found out today while putting my cat back on for smoag that the reason my shifter fell down and was rubbing on the heat shield is that the only thing holding the whole shifter and shifter rods up into the car is a single bolt going into some sort of hard rubber. soooooo to fix that i have to jack up my car again and replace the ENTIRE opening into the car. luckily its only about $20 at tustin nissan. im ****ed
Old Jan 21, 2003 | 01:31 PM
DanNY's Avatar
Ad·min·is·tra·tor
Re: Nissans Poor material choices
so you're here to say that you're upset that a part on your car only lasted 13-14 years? may be a poor choice in your opinion but i'm sure the engineers made the part out of rubber for good reason.
Old Jan 21, 2003 | 02:17 PM
ocMax's Avatar
Re: Re: Nissans Poor material choices
True.
Old Jan 21, 2003 | 02:31 PM
drstillpatient's Avatar
oCMAX...
man i got the same exact problem...on my 89 SE.
just ordered that bracket from courtesy nissan for 28bucks!!!
u sure its for $20 at tustin? i cant believe KALEB f*cked me on the price of that one. confirm the price man...the part number i ordered was 34560N.
i'll give courtesy another call if tustin has a different price.
Old Jan 21, 2003 | 04:36 PM
lophix's Avatar
Originally posted by drstillpatient
oCMAX...
$8 dollars isn't exactly what i'll call "f--ing". Afterall you didnt shop around to see if it was cheaper anywhere. Kaleb helps a lot of people out whenever he can, and it's not his job to reduce prices for people who dont ask. Sorry but I just had to get that out since it sounded kind of rude and demeaning to Kaleb.
Old Jan 21, 2003 | 04:46 PM
yup thats why i said i cant believe kaleb would do that
about those 8 bucks...well umm...lets say right now they are a big deal for me...i know that sounds cheap...but my situation aint great right now so it matters somewhat...but you're right...not really best choice of words there.
oh hey Kaleb...no offense intended.
Old Jan 21, 2003 | 05:02 PM
lophix's Avatar
that's why i love the org. almost everyone is very mature about stuff, which is a big plus Okay, back to the topic: is it a normal thing for the shifter to fall? or is it among autos? Kinda scary, lol cos I drive 150miles everyday and dont want my shifter to fall on the freeway lol. I need a newer car: 183k miles on a car and putting 750miles on it a week isn't really assuring.
Old Jan 21, 2003 | 05:11 PM
mine's a 5-speed. You can actually move the shifter up and down quite a bit cuz of the broken bracket!! but shifting is still not a problem...it shifts perfectly.
dont know if the autos would have the same problem.
Old Jan 24, 2003 | 04:22 PM
MethMax's Avatar
Broken Shifter Boot
Yeah I dont think that it would happen to a auto. The 5-speed boot take a lot more abuse. I also think that the 5-speed shifter is more xposed from under the car (never seen an undercarage of an auto). My boot broke on my car and I left it alone for a couple of months and it didnt really bother me at all. I used a hagger to fix it so thats something you could do drstillpatient.
Old Jan 24, 2003 | 04:58 PM
just received my new bracket for the shifter...will put it in on monday.
Old Jan 25, 2003 | 01:08 AM
tmnismo91's Avatar
oCMAX...
Consider yourself lucky you got it for that much. I think I paid a little over $60 from a Nissan dealer here in Northern California.
Old Jan 25, 2003 | 01:33 AM
i DO i DO!!
the packing slip says the list price is $40.44 from Nissan...how come you got it for $60??
btw...how much was the labor for putting this part in? can it be replaced from inside the car or you gotta go past the exhaust beneath the car?
Old Jan 25, 2003 | 08:14 AM
Mike S.'s Avatar
I've always maintained that Kaleb was an A-Hole!
I'm kidding guys! He's helped me out many times in the past!
Old Jan 25, 2003 | 09:44 AM
tmnismo91's Avatar
Missed it by a few numbers.....
i DO i DO!!
After looking at my invoice I realized that I got the holder bracket for $43.17. I don't know why I was thinking it was sooo high.
Old Jan 25, 2003 | 02:10 PM
ocMax's Avatar
Re: Missed it by a few numbers.....
i got mine for 56 list and 30 net. (tustin nissan) put it in yesterday. If you ever end up replacing that whole housing it would be a good time to get a short shifter cuz u have to take the shifter off to do it.
Old Jan 25, 2003 | 04:29 PM
mykizism's Avatar
Yah worD up Kaleb is coo, on my list
Old Jan 25, 2003 | 05:27 PM
Re: Re: Missed it by a few numbers.....
hey OC...
i'm gonna be putting the bracket in on Monday...do you change it from inside the cabin or from beneath the car? do u got a
write-up for it (if it even needs one)?
Old Jan 25, 2003 | 08:13 PM
ocMax's Avatar
Re: Re: Re: Missed it by a few numbers.....
hey OC...
heres how it goes. . . jack up the car and remove the catalytic converter. Remove the heat shield. (5 phillips/10mm screws) You will then see 4 bolts around the outside of the pieces yiou are replacing. remove. (remeber wich bolts go where with what washers there all different) remove the little spring you see conecting the 2 shifter rods. remove the 4 bolts on the bottom piece of the shifter. Pry/lift the top part of the shifter off the bottom. at this point everything should be really loose. push the shifter up through the whole it is shoved into. (will be extreamly difficult you will figure it out) no that theres enough clearence take the old metel housing thing out and put everything back together. Once you get under there and look you will be able to figure it out. It might help to have another person on top in the car so they can wiggle/push/pull shifter around. i hope that helps!
Old Jan 26, 2003 | 01:10 AM
Re: Re: Re: Re: Missed it by a few numbers.....
Thanks!
Time to get dirty again!
RinconI30
Nov 10, 2015 10:55 PM
carid
Sep 9, 2015 05:06 AM
Maxboy23
Sep 4, 2015 06:04 PM
coasterswim
Sep 2, 2015 07:43 AM
