vibration
Old Jan 29, 2003 | 03:26 PM
maximizeditalia's Avatar
vibration
So i have a vibration when i accelerate but only between 1500 and 2000 rpm,s that is when it is strong. Then i can fell a little vibration when i am driving. But if i let off the gas or if i keep it in neutral or park it is fine. What could it be?
Old Jan 30, 2003 | 06:01 AM
shvelle's Avatar
Since nobody else has replied - I'll guess at some possible causes.
If the vibration is purely associated with the Engine's rpm:
-worn engine mount(s)?
-bad spark plug wires or distributor cap?
If the vibration is purely associated with the car in motion:
-low air pressure in tire(s)?
-Wheel bearing going bad?
-Bad tie-rod end?
-Bad ball-joint?
-thrown belt in tire?
-lost balancing weight from rim(s)?
-loose strut(s)?
Anyways...., those are just guesses, but better than nothing I suppose.
Old Jan 30, 2003 | 06:56 AM
doomtoo's Avatar
If you want to check if it's an engine mount(if it's that little rubber thing), have a friend help you with it. One of you look at the engine while the other does a couple quick revs. If a mount is gone, the engine will "jump around" pretty strongly.
(thats the only one I may be able to help with, I got an idle vibration )
Old Jan 30, 2003 | 07:55 AM
«§»Craig B«§»'s Avatar
that is true, but I dont see why you need a friend. The throttle cable is right there on top of the engine at the throttle body, you can just move that yourself while looking at the engine
Old Jan 30, 2003 | 12:30 PM
actually i just replaced all motor mounts as well as the tranny mount and it is still doing it
Old Jan 30, 2003 | 02:36 PM
Logan91VE's Avatar
something wrong with the exhaust?
i had a toyota with a busted resonator that would _always_ rattle at 4000rpm
Old Jan 30, 2003 | 02:49 PM
i dont know about that, well it only vibrates when i am giving it gas and it vibrates more when i first take off from a dead stop!!
user 11122324
42
Jul 18, 2022 03:35 PM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
06maxima55
Sep 28, 2015 04:29 PM
alahjahwan09
18
Sep 21, 2015 09:12 PM
Bonka
Sep 14, 2015 11:18 PM
