car is making a tick sound
car started making a funny sound a little while ago. it only happens when im accelerating. Its sounds like chick chick chick,and im sure its coming from the engine bay, not the exhaust. any ideas? thanks in advance
yes you can replace them, just as long as you pay and it's not an easy job and most likely it's the exhaust studs located in the back by the fire wall which makes it much harder. I recommend taking this to a good mechanic and make sure you get good quality studs so ths never happens. This job will run you a lot and expect to pay.
Originally posted by acidspit86
what is a good site to order these bolts from? how much do you think it will cost to get those replaced?
what would happen if i were to just ignore this problem? performance loss? just that clicking sound? or would something serious be caused?
well yes you would loose power and eventually the noise get worser and worser.
Re: car is making a tick sound
Mine goes away after it warms up. Mechanics I spoke with(private garages and Nissan) said it only had to be fixed if it bothered me that much, otherwise no ill effects. It's passed the emissions with no problems in the 6+ years I've had it...
mine doesnt go away, sounds like its gotten a little louder
Originally posted by rustangkilla
Expect to pay around $500 for an exhaust stud job. The parts were cheap, but labor just r@ped me. They had to take a ton of parts off and and do some heavy duty extracting. Not to mention it is a dangerous job...drill to far in and your through a cylinder wall. Just something to think about if you decide to do it on your own.
Lakersallday24
Jun 16, 2019 01:35 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Jcof88
Aug 3, 2015 10:43 PM
