Knock Sensor replacement
Old Feb 21, 2003 | 08:50 AM
Gjohnson's Avatar
I found this site earlier, but I think its for a 4th gen.
http://www.motorvate.ca/auto/maxima/...ock_sensor.htm
I got my knock sensor in the mail today from Courtesy, but after looking at the write up on 4dsc.com I don't know if I can do the work myself. The only mechaninc work that I have actually done to this point is cleaning the throttle body and replacing the fuel filter. Has anyone else completed this task, and recommend a DIY. Or should I take it to a shop, the place that tested the sensor had qouted me at $575 for parts and installation.(that includes the cost of the knock sensor)
Old Feb 21, 2003 | 09:11 AM
nubiannupe's Avatar
OG Maxima.org Member
Believe me... I thought the same thing when I did my injectors. But as long as you've got a semblance of patience, you should have NO problem doing this. From the write-up's I've seen, it's pretty much the same thing as when I replaced my fuel rails/injectors in regards to taking off the intake manifold. But if you've got doubts, take a day or two to do it, keep hitting us up on the .org, and I'm sure we'll get through it.
Heck, you can call me if you want and I can TRY to help out. Let me know.
Old Feb 21, 2003 | 11:20 AM
Gjohnson's Avatar
Alright playa, I try to hype myself up and go at it. I just hope I can do it by the end of the weekend cause I have to be to work on Tuesday. BTW, nubiannupe I was checking out your profile and we have the same birthday.
Old Feb 21, 2003 | 01:45 PM
Agamemnon's Avatar
Of course you have to also consider whether you have alternative transportation, in case it took longer than you expected! (as I'm sure it will! ) Plus you probably gonna have to go to the parts store during the procedure to get something!
Old Feb 21, 2003 | 07:21 PM
eric93SE's Avatar
GET THE SUB-HARNESS CABLE BEFORE YOU START THE JOB.
the info for the cable is in the FAQ at the top of the page I believe. The main problem with the KS is that the terminals corrode due to the dissimilar metals that nissan used between the cable and the KS.
Old Feb 21, 2003 | 09:39 PM
Gjohnson's Avatar
I bought the sensor from courtesy and it came with a sub harness. The only thing the offer is the knock sensor kit including sensor and subharness. Looks like I'm going to have to take it to the Mechanic on Monday, I don't have the time or tools to do it myself and I can't aford to be without a car more than a day. I've got a mechanic that will install it for $200.
Old Feb 22, 2003 | 07:41 AM
nubiannupe's Avatar
That's what I'm talkin' bout! Pisces in da house, y'all!!! Too bad you're not closer, or I'd give ya a hand with that and save you the $200! But I know you gotta do what you gotta do.... Let everyone know how the install goes, and if the mechanic will let you, get some pics!
Old Feb 26, 2003 | 08:53 PM
Gjohnson's Avatar
Ok, got the knock sensor replaced yesterday. Drove awesome last night and all day today. Stronger than ever. But on the way home tonight the car starts acting up again. Stalled on me just driving down the street, then started bucking. I haven't got a chance to reset the ECU since the replacement (With all the snow and lack of garage living in an apartment.) Could it be acting up because of the codes saved up in the ECU? I ran a test an its no longer giving me a knock sensor code, but in the write up on 4dsc.com it says reseting is a must. What's going on? I hate this crap.
CorollaULEV
30
Aug 9, 2021 08:11 PM
kjlouis
Nov 24, 2018 06:09 AM
maxinout93
Oct 27, 2015 01:29 PM
Maxboy23
Aug 21, 2015 11:02 AM
maxinout93
Aug 20, 2015 02:17 AM
