Hooking up extra gauges
Old Mar 2, 2003 | 10:31 PM
Spipedong90's Avatar
Anybody have extra experience with extra gauges? Particularly oil temp, oil pressure, and water temp.
What I'm asking here is where are good places to stuff the senders on these at? Do I use T-Fittings so the factory junk still works?
Old Mar 3, 2003 | 05:26 AM
N34JZ's Avatar
Needs non-Maxima Friends
usually they send an electronic sender unit with the kit, you tap into the line with a t fitting (suplied) and screw the sender unit on and that transforms the reading or measurement into and electric signal then you just run wires from the sender to the gauge. Thats how my fuel pressure gauge was anyway
Old Mar 3, 2003 | 09:39 AM
Right. I'm looking for help on where the senders go.
Do I just find the factory oil pressure sender and use a t-fitting on that?
Old Mar 3, 2003 | 09:47 AM
Matt93SE's Avatar
STFU n00b!
yes.. that's fine. usually they're the best places to put them.
Old Mar 3, 2003 | 11:24 AM
N34JZ's Avatar
if you buy gagues they will probably come with the sender then you can tap in after the factory one, i dont think you could use the factory one, I put my fule pressure one right after the filter
Miket2006
Mar 1, 2021 03:55 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
220k+ A32
18
Sep 22, 2015 11:39 AM
RWCreative
Sep 21, 2015 11:01 AM
