went to the track
Old Mar 10, 2003 | 11:01 AM
furious max's Avatar
went to the track
wasup people. i went to the track this past saturday. they had the street wars in nj and it was the bomb. i saw the only max out there did a 15.4 next to a honda bubble back. anyboday was out there? holla at me.
Old Mar 10, 2003 | 11:13 AM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
Re: went to the track
pretty good times....can you post all of the stats form your slip??
Old Mar 10, 2003 | 11:38 AM
Re: Re: went to the track
it wasn't me it was this guy from jersy. but it ran really good. i think the next street wars are goin to be in june.
Old Mar 10, 2003 | 01:33 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
what track did you go to?
Old Mar 10, 2003 | 01:45 PM
Matt93SE's Avatar
STFU n00b!
it wasn't running "really good" unless it was in the 14s. a VE stick should run faster than that bone stock.
Old Mar 10, 2003 | 01:47 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
maybe it was a VG auto
Old Mar 10, 2003 | 09:38 PM
i went to raceway park in englishtown nj. and it was a vg stick. the track from what i saw was kinda a slick that day. lots of cars didn't have a lot of traction.
Old Mar 10, 2003 | 09:57 PM
Matt93SE's Avatar
STFU n00b!
In that case, 15.4 is a pretty good time.
Old Mar 11, 2003 | 08:42 AM
Kevincleff's Avatar
Once I get the exhaust studs, fuel injectors, and fuel lines replaced then hopefully I can find out what this VE 5sp can do
Chris we should hit englishtown up one weekend. Let me know what weekends are good for you!
Old Mar 11, 2003 | 10:55 AM
Matt93SE's Avatar
STFU n00b!
It'll do a lot better than a 15.4, I'll tell you that much!
I ran a 14.99 a few weeks ago on a track that EVERYONE was running a 1/2 second slow... So that made me feel pretty good..
then I found out last weekend my O2 sensor and knock sensor are both completely dead (i.e. registering open circuit on a multimeter = NO operation at all)
So I replaced the O2 sensor and bypassed the knock sensor.. I'd say it added 10-12hp, conservatively.
mid 14s? noooo problem.
Old Mar 11, 2003 | 11:33 AM
eric93SE's Avatar
Stick you head out the window when running the engine hard, listen for the snap-crackle-pop . It will detonate (I can promiss you that). Just pray that it doesnt burn holes in the piston heads.
Old Mar 11, 2003 | 04:28 PM
Aaron92SE's Avatar
NWP Engineering.com
I did this same bypass. Mine only detonated if I had my timing at 20 degrees with 93 octane. But I put it back to 15 degrees and no more detonation. I just did this bypass as a test and it definitely helped my performance while hot. Now I am back to my stock dead KS.
Old Mar 11, 2003 | 05:33 PM
subs1000w's Avatar
i did the bypass also and it made a huge difference and i left my timing advanced and i dont hear anything abnormal
Old Mar 11, 2003 | 06:07 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
i'm down for anytime after march. i get back from vacation on the 5th of april and there's a show at etown on the 6th or i may go to the Rutgers meet.
my car is doing a tour through various shops in the region it should be out in your neck of the woods this weekend actually
Old Mar 11, 2003 | 07:23 PM
Kevincleff's Avatar
where?? i wanna know please!
Old Mar 11, 2003 | 09:26 PM
Matt93SE's Avatar
STFU n00b!
Really? first thing I did after the bypass was to get the engine REALLY hot by driving the **** out of it (with the bypass off), then I plugged it in and drove around the neighborhood in 4th and 5th gear, below 1200rpm.. even floored, it NEVER detonated- or at least never sounded like it was... and yes, I know what it sounds like.
Old Mar 11, 2003 | 09:33 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
*cough* tilley *cough*
mkaresh
Mar 12, 2018 06:48 PM
jonreidhead
Jan 6, 2016 09:38 AM
