Running Hot
Old Mar 16, 2003 | 11:19 AM
Mike92GXE's Avatar
Running Hot
On two seperate occasions I have noticed that my temp gauge is pretty close to the top. I pull over the first time and notice that i need some coolant so i put some in and the needle goes back down. A few days later it happens again but this time my coolant isn't low but i put some in anyway and the needle is in the middle of the temp gauge for the rest of the trip. Can you guys think of anything else i should be checking when it comes to your car running hot? I don't think i have a leak because the second time the coolant level was fine. Your feedback is appreciated.
Old Mar 16, 2003 | 11:25 AM
Jeff92se's Avatar
I'm needing a caw
Check
4 leaks
water pump
thermostat
clogged radiator
leaky hoses
Procedures can be found here or a service manual
Old Mar 16, 2003 | 02:08 PM
N34JZ's Avatar
Needs non-Maxima Friends
I had a similiar problem last night but only when the car idled for more than like 10 minutes it would heat up untill I started driving again, Im gonna try the thermostat this week
Old Mar 16, 2003 | 03:58 PM
Mike92GXE's Avatar
Originally posted by Jeff92se
Check
4 leaks
water pump
thermostat
clogged radiator
leaky hoses
I haven't found any of the procedures on the site but i'll check my Haynes Manual. If anyone has the FSM for a 92 GXE I would appreciate a copy of any pages that have to do with the tasks listed above. One of the links no longer works,
http://www.cybrrpartspro.com/Chilto...8961m/8961.HTML
Any help would be appreciated.
captchaos
Mar 15, 2016 12:18 PM
RWCreative
Sep 21, 2015 11:01 AM
conansriver
Sep 11, 2015 10:26 AM
ballerchris510
Sep 10, 2015 09:35 PM
