How hard do you think to make door lights light up by switch...?
Old Jan 14, 2001 | 11:14 PM
Brandon90gxe's Avatar
i ahve the blue lights in my doors, and map lights and i was sitting out in my max tonight with the door a crack so the lights were on w/o the dome and it looked sweet. just the 4 doors and the 2 map lights made a hella cool blue glow throughout the whole car, and i was wonderin how hard it would be to hook up the door light to a switch so i could turn em on whenever i want, or hook em up to like the parking light swith so they turn on when i turn on my parking lights....what do you think, is it too much of a pain in the ***? i was also thinking about blue neon lisence plate frames for under the seats, hmmm... opinions appreciated....
Old Jan 14, 2001 | 11:46 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
Hmm.....
check out Craig B's info on "Using Relays"--> <a href="http://www.prism.gatech.edu/~gte671n/relay.html">Relay Stuff</a> you could run the light power wire through a relay and then run a switch into the relay, that might work?! BTW, what type of lights are used in the map lights (are they 1156 or 194 bulbs???) thanks
Old Jan 14, 2001 | 11:59 PM
im not im not sure what type they are, i know theuyre not 194, cause those are what are in the doors, they are more round. just pry off the cover on the map lights and check it out, use a flat edge screwdriver. sorry.
vingodine
45
May 21, 2016 12:46 PM
King_Ten_Ahead
Sep 30, 2015 04:27 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Blackwind
Aug 5, 2015 06:35 PM
