injectors
Old Apr 4, 2003 | 11:02 AM
chottomax's Avatar
injectors
Does anyone know where I can find fuel injectors at a good price. The cheapest price I could find was 90 bucks a piece. Thanks!
Old Apr 4, 2003 | 11:13 AM
doomtoo's Avatar
Re: injectors
Yeah, I need some too. Just got a quote for 5 to be changed - $1090!
I barely made that much last year. With remanufactured ones it's going to cost ~$700
Old Apr 4, 2003 | 11:26 AM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
http://www.directauto.com/
should be ~$40-50 per injector, they are rebuilt...email them!
Old Apr 4, 2003 | 11:46 AM
chottomax's Avatar
thanks!!
You are DA MAN!!!
Old Apr 4, 2003 | 02:54 PM
doomtoo's Avatar
Re: thanks!!
Originally posted by chottomax
You are DA MAN!!!
Yeah, thanks, this'll help me out alot in a couple months, when I can afford new injectors!
Old Apr 4, 2003 | 03:14 PM
DA-MAX's Avatar
no prob, thats where I got mine. I think bryan91se got his there too, he reccomended them to me last fall!
Old Apr 4, 2003 | 03:43 PM
Laly's Avatar
damn, i paid 140 with o-rings and taxes from the dealer. or should i say stealer. i was robbed.
Old Apr 4, 2003 | 05:31 PM
ocMax's Avatar
ya I got mine from Direct aouto and so far so good
Old Apr 5, 2003 | 10:30 AM
chottomax's Avatar
injectors
Can someone give me an idea of the time I should expect it will take to swap out my injectors if I do it myself? These crackjack mechanics aroung here want to charge me $600 in labor! Thanks!
Old Apr 5, 2003 | 10:49 AM
ocMax's Avatar
Re: injectors
its not to hard you will need some new gaskets though. it should take you bout 1- 1 1/2 hrs if your good.
http://members.csinet.net/tisch/maxima/ has a write up if you click on the fuel injector link on the main/FAQ page
Old Apr 5, 2003 | 12:52 PM
Spipedong90's Avatar
Sorry to hijack the thread, but what's the definitive way to know if the injector's bad? My car surges alot and has alot of hesitation/missing. I can unplug 2-3 injectors before it makes a difference. When I measure them with the meter they all read about 11.7 ohms, which I belive is what they should be...
Old Apr 5, 2003 | 12:58 PM
DA-MAX's Avatar
1-1/2 hours only if you are good and have the GREATEST LUCK IN THE WORLD! took me a few days...if the O-rings don't seal properly or you don't seat the injectors right, the process gets to be drawn out...my advice is when you do the injectors don't jump into it thinking "this is gonna be simple", if not done right it can turn into a tedious task! but its a perfectly doable DIY job, just take your time and don't get discouraged if when you put it all back together and the car is running like shat(I know I was ****ed off )...just go back and try again!
Old Apr 5, 2003 | 04:44 PM
chottomax's Avatar
injectors
Thanks for all your help! I've ordered the injectors from directauto.com and got the rest the parts locally. I'm going to replace them next weekend.
Old Apr 15, 2003 | 07:32 PM
chottomax's Avatar
Re: injectors
By the way, can anyone educate me as to anything else I should be repairing/replacing while I am replacing the injectors? Any insight would be much appreciated!
Thanks!
Old Apr 15, 2003 | 08:40 PM
todamax's Avatar
I've got 4 good injectors that I pulled when I replaced all 6 in my '93 GXE a year and a half ago.
And on the flip side, I need 2 for my '89....
Old Apr 15, 2003 | 08:46 PM
DA-MAX's Avatar
Re: Re: injectors
Thanks!
upper intake manifold gasket(s) and any cracked or hard/brittle hoses
some other random stuff, but helpful since the manifold is off would be to clean the TB, give the manifold at least a once over with a brush and carb cleaner, clean the IACV valve assembly, change the fuel filter for a good measure and replace the PCV valve (if not already).
Old Apr 15, 2003 | 11:40 PM
chottomax's Avatar
Re: Re: Re: injectors
Thanks again for your help! Hopefully I will finally get my injectors by this weekend and be rollin in my Max again. The car I'm drivin now sux compared to my 4DSC!
Maxboy23
55
May 1, 2025 06:09 PM
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
msellas
Sep 23, 2015 09:16 PM
