Cheapest Performace Mod
I was curious to know what the cheapest performace mod is, since I'm on a tight budget. One of my friends told me that getting an exaust system put in is the cheapest, but I'm not sure...
Ben
Ben
Re: Cheapest Performace Mod
Ben
Ben
Re: Re: Cheapest Performace Mod
Originally posted by Fosgate Fan
you can always begin with removing that stock air box and replacing it with a pop intake. full exhaust systems ain't cheap. just start with an intake and work your way up from there.
cheapest mod? advance the timing. its free.
second cheapest? throttle body coolant bypass..less than $3
intake is third and you'll notice a good difference from it (approx. $40). after that, probably underdrive pulley, removed AC belt and then its on to the exhaust but that gets costly.
Originally posted by Chris91SE
cheapest is stickers...
as for how to advance the timing...go here:
http://www.prism.gatech.edu/~gte671n/mymax.html
there's lots of stuff in the how to section.
[QUOTE]Originally posted by EdzMax
[B]
loosen dist. bolts, turn in proper direction the specified amount, check with timing light..there ya go..obviously i know nothing about VGs.
on a VE, you loosen CAS, turn toward the rear of the car, tighten and call it a day.
[B]
How do you do that? Just curious.....
hey fellas you missed the important one! if you're driving a manual, knowing how to DRIVE it would be by far the cheapest and best. hell even an auto there's a few trick sto get the best launch.
Originally posted by s9am_me
whats a good intake filter to replace the stock air box?? the JWT pop charger seems a little on the high side
or would it be better to replace the whole piping?
i went with a k&n filter and custom adapter to fit it on.. good mod... moderate price for good results.. you could go with a cheaper filter.. but i trust k&n's quality
did you buy that custom adapter? or made it yourself?
dvcamp
Sep 18, 2015 10:17 AM
