Sway bar bushings
Apr 20, 2003 | 08:59 PM
I would like to get some polyurethane bushings for replacement. Energy Suspension came to mind, but they didn't have one specific to the 3rd gen.
Any ideas where I can get a replacement set? Thanks,
Apr 20, 2003 | 09:07 PM
energy makes some that go on the suspension techniques sway bar... I believe the bushings are the same size, and since they bolt into the same place, I would assume they will fit on the OE sway bar..
see what you can find for the ST sway bar set...
btw.. if you're still running the factory sway bars, I highly suggest getting the Addco rear or the Sus Tech front and rear set. makes an amazing difference in handling.
Apr 20, 2003 | 09:41 PM
I dont know about the other pieces, but I have a set for the front sway bar endlinks (aka connecting rods). They're Energy Suspension generic import sized ones that I got at PepBoys - about $8 for a pack of 8, but you'll only need 4 for fronts. The inner diameter would be nice if it were about 1mm larger. It's a tight fit but still works fine.
Part Number is 9.8105GC
Apr 21, 2003 | 03:38 PM
Or you can call Kaleb at Courtesy, and tell him you want Energy suspension endlink bushings for the FSB.
www.courtesyparts.com
Matt is right tho, get an Addco RSB at the least.
