Has anyone replaced a camshaft oil seal?
Old Apr 21, 2003 | 04:17 PM
davemaher's Avatar
I recently located an oil leak that I have been searching for. It seems to be a bad camshaft oil seal (near the timing belt sprocket). Since I just had the timing belt done by the dealer 6 months ago, I would rather do it myself. Is there any things I should watch out for when I do this?
Old Apr 21, 2003 | 05:22 PM
Engloid's Avatar
Re: Has anyone replaced a camshaft oil seal?
I hate it for you, but the money spent at the dealer is wasted money...you have to take it all back apart as if you are replacing the belt...
If I were you, I'd go ahead and replace it while it's off even though it's not old. It's worth $22 to get another 6 months use out of the car.
The seals are cheap. Do the crank seal and both cam seals. It's best to do them when you do the timing belts...too late now though.
The flat side of the spring goes out. Push it only flush with the outside of the head or it push in too far and leak.
Starrider
Sep 17, 2015 07:26 AM
iflexsteel
Sep 15, 2015 03:37 AM
Rage Maximus
Sep 3, 2015 12:26 PM
tnewbs
Aug 28, 2015 10:15 AM
maxinout93
Aug 20, 2015 02:17 AM
