Not The Average E-36 Question
Old May 5, 2003 | 08:19 AM
shock211's Avatar
Hey guys,
I know that e-36 swap threads are all over the place but i couldn't find a specific thread for my question.
so here goes:
Yesterday i was trying to take apart the e-36 headlight assembly using a heat gun and a puddy scraper(to help pry out the lense).
I need to remove the clear lense, bulb cones in the back and glass circles. i'm doing this because i want to clean and polish everything as well as add in angel eyes.
I must have been going at this for 45 minutes! and this **** isn't coming apart???
has anyone here taken the whole assembly apart? if so I need some advice. this is weird because the heat gun should work.
any suggestions are appreciated.
Old May 5, 2003 | 09:11 AM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
US Spec lights aren't easy to dissassemble. check some bimmer forums. i'm pretty sure one has a write up but i can't remember which one
Old May 5, 2003 | 10:32 AM
Dark Lord Bunny's Avatar
Just get Euro specs.
Old May 5, 2003 | 10:53 AM
shock211's Avatar
they look great....but they're too much $$$
Old May 5, 2003 | 11:22 AM
SeaMAX's Avatar
I took a dremel to mine and just glued it together after I was done.
Old May 5, 2003 | 12:44 PM
Delvin's Avatar
Euro spec with the angle eyes already installed is the easiest way to go.
Old May 5, 2003 | 12:51 PM
Brandon90gxe's Avatar
i used a hairdryer, and they came out fine.. just heat it and pry it and keep doing it.. then you can just push the glass out once you get the cone off..
Old May 5, 2003 | 01:56 PM
shavedmax's Avatar
need more pics of your car, i like the kit, where'd you get it?
Old May 5, 2003 | 02:55 PM
James92SE's Avatar
2 VE's are better than one!
It's a modified WW front and WW sides with a modified Stillen rear
Old May 5, 2003 | 03:39 PM
shavedmax's Avatar
nice job
Old May 5, 2003 | 04:00 PM
shock211's Avatar
well i guess i'll give it another shot....but it's gonna take quite some time to finish.
i'll probably also try asking some bimmer forum people.
Old May 5, 2003 | 06:54 PM
once it gets hot enough it should just pull apart, just do it section by section and pry it with a screwdriver...
Unclejunebug
Apr 2, 2016 05:42 AM
ef9
Oct 4, 2015 08:43 AM
Socalstillen
Sep 26, 2015 12:01 PM
