Please Help to Diagnose... Coolant Leaking...
Old May 9, 2003 | 05:20 AM
crsmax's Avatar
I had coolant leaking from the passenger side of the car from right around where the sway bar sits. Coolant was on the ground in a straight line perpendicular to the front sway bar. Looked under the car and area looks moist. Have not driven car in a week, and after I started it up and let idle for two minutes, I reved it to make sure oil was fully into system and noticed the leak. Checked temp, car is not running hot. Resovoir still had plenty of coolant left, and no visible leaks from the top front or rear of engine. Any ideas??? A bad seal possibly?
Old May 9, 2003 | 05:54 AM
nubiannupe's Avatar
OG Maxima.org Member
Re: Please Help to Diagnose... Coolant Leaking...
I just noticed the same thing with MY car recently. I can't really help ya, but I'm hoping someone might help BOTH of us.
Old May 9, 2003 | 06:16 AM
crsmax's Avatar
Re: Re: Please Help to Diagnose... Coolant Leaking...
I just noticed the same thing with MY car recently. I can't really help ya, but I'm hoping someone might help BOTH of us. [/B][/QUOTE]
Yeah, thanks for the support... I hope it is just something minor...
I think it is a seal. I haven't had a chance to jack the car up yet, but perhaps this weekend...
Old May 9, 2003 | 07:00 AM
Gjohnson's Avatar
Good luck guys, I'm not sure myself, but I know when my car was leaking like this I had to change my water pump. Hopefully you guys want have to do this.
Old May 9, 2003 | 07:19 AM
DanNY's Avatar
Ad·min·is·tra·tor
i'm going to guess either a failing water pump or a leak in a heater/coolant hose. jack up the car and crawl under and if it's wet around the water pump.
Old May 9, 2003 | 08:04 AM
crsmax's Avatar
Thanks for the info. Weird thing is... that after car sat over night... no visible leaking on the ground. I will check a.s.a.p.
Old May 9, 2003 | 08:28 AM
DanNY's Avatar
Ad·min·is·tra·tor
leaning more on waterpump.
when you park the car there should be no leak...heat swelled up the seal.
but when you start it in the moring it's drip city
Old May 9, 2003 | 09:24 AM
crsmax's Avatar
Thanks DanNy... hopefully I'll get it fixed this weekend... what is the usual cost on the water pump?
After I get this straight, I'll send out the $$ for the shift boot.
Old May 9, 2003 | 09:45 AM
medic's Avatar
the pump is just $100 if I remember right. The PITA is that you need to remove the belts and timing - that's what will cost you if you go to a shop
Old May 9, 2003 | 12:56 PM
crsmax's Avatar
Cool. Thanks for all the info fellas...
Old May 10, 2003 | 07:23 AM
Gjohnson's Avatar
You have to remove the timing to replace the water pump? I didn't know that and I had my water pump replaced a couple months back. So I guess my timing could easiluy be off. Now, if I only had a timing gun and knew how to use it.
Old May 10, 2003 | 07:53 AM
DanNY's Avatar
Ad·min·is·tra·tor
for VG you should replace the T-belt while you're there.
VE you don't have to do anything else but fan belts.
Old May 10, 2003 | 08:34 AM
Gjohnson's Avatar
Ok, cool. VE power, baby!
Old May 10, 2003 | 09:04 PM
crsmax's Avatar
Problem Solved...
Luckily it was just the upper hose that had a hole in it.
It was leaking directly onto the belts, so now I have to replace some belts, but other than that everything else checked out ok. Thanks again for all of the help and sugestions.
Old May 11, 2003 | 12:27 AM
max raven's Avatar
I have a TSB on this issue but I don't know how to post a .pdf file.
Maybe I can send it by email.
Miket2006
Mar 1, 2021 03:55 AM
captchaos
Mar 15, 2016 12:18 PM
foodmanry
Sep 24, 2015 12:02 PM
msellas
Sep 23, 2015 09:16 PM
junito1
Sep 23, 2015 12:14 PM
