FSTB question
Old May 14, 2003 | 08:15 PM
MaximaGuy719's Avatar
FSTB question
Just got mine a second ago, I'm facing the car, do the screws turn clockwise or counter clockwise?
Sorry search isn't working
Old May 15, 2003 | 11:06 AM
«§»Craig B«§»'s Avatar
same as all the other screws/bolts on the car
righty tighty, lefty loosey
unscrew by going counterclockwise
Old May 15, 2003 | 11:23 AM
Methamphetamine's Avatar
bwaha, good luck on gettin those off...they're on there TIGHT
Old May 15, 2003 | 12:25 PM
noleafclover's Avatar
You could be facing any direction and they would still be counterclockwise unless you're upside down...then i guess it'd be clockwise...j/p with ya man.
oh and when i put mine on i used a pvc pipe that fit right over my rachet...2 foot breaker bar...works perfectly.
Old May 15, 2003 | 10:51 PM
Those f'n old *** screws!!!!!!!!!!!!!
Can't get the screws off, the damn metal on the screws is peeling with every turn.
Old May 16, 2003 | 08:28 AM
atulb84's Avatar
spray some double you dee fourtee.
Old May 16, 2003 | 03:02 PM
I'm defeated.
I've been going at these screws for almost 2 days, even took it to my friends house and no dice. My old *** screws won't come off and are worn down now. I was thinking of sawing 'em off and replacing them, good idea?
Old May 16, 2003 | 03:40 PM
LegitMafiaBoss's Avatar
I'm defeated.
When I installed my fstb the bolts on the strut mount broke so I had to saw off the nut and bolt across the middle to get it off. I ended up replacing my springs, struts, and mounts for the heck of it after trying to install my fstb.
Old May 17, 2003 | 10:55 AM
Is there any other way to those nuts?
Old May 17, 2003 | 11:04 AM
nut splitter would probably work, you can get one at pepboys or any hardware store
it is basically a point that you push into the nut (using a socket) and it cuts through the side of the nut
or try using some vice grips maybe
Old May 17, 2003 | 11:16 AM
D-sta's Avatar
First time I hear of anyone having trouble with the strut mount bolts. When I did my suspension and FSTB install they came off with no problem and they were on pretty tight also. I think I used a 13 or 14mm socket where its pretty snug around the bolt and won't allow it to slip and strip.
Old May 17, 2003 | 11:48 AM
The nuts broke the f'n nut splitter, lol.
"First time I hear of anyone having trouble with the strut mount bolts."
Yeah I know, seems like it's impossible to have problems with 6 bolts, easy 14mm job, but my nuts stripped and they're now round with no grip.
Old May 17, 2003 | 02:05 PM
AscendantMax's Avatar
it broke the nut splitter?
get some good vice grips, lock that thing on that nut hella tight and see if can get it off.
or go to sears and get some of that rounded bolt/nut remover. see if you can get it out with those. grab a can of penetrating oil while you at it. it may help you with future projects
good luck
Old May 17, 2003 | 03:25 PM
good luck
Yup broke the nut splitter, quick and easy mod has been going on since thursday.
Old May 17, 2003 | 03:32 PM
todamax's Avatar
wow, I've put an FSTB on 4 different Maximas and not one was a problem like that...
Old May 17, 2003 | 03:49 PM
D-sta's Avatar
thats what I'm saying
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
