Help on cracked Y-Pipe..PLZ!!!
Old May 14, 2003 | 11:47 PM
Torres's Avatar
ok here is the problem...
yesterday i received a WSP y-pipe from DA-MAX and i got it cracked..well more like a hair line crack but i'm thinkin' this will screw my Max more....but then i was thinkin' if i weld up that crack and is that goin' 2 hold it or make it worst then it is????
so fellow 3rd gen members PLZ help me out by answerin' this question???
can the crack be welded and it will be fine????
Torres
Old May 14, 2003 | 11:59 PM
subs1000w's Avatar
1st wheres it cracked but more than likely welding it up should be fine
Old May 15, 2003 | 12:05 AM
Torres's Avatar
ok the crack is located near the 2nd pipe or back pipe...and on top...the crack is like 2 inches....
thanx 4 the quick reponse
Torres
Old May 15, 2003 | 01:24 AM
Maxpwer's Avatar
No turbo, no care!
a hairline crack two inches long can EASILY be welded, perhaps 15 seconds. if you were in chicago i would do it for you
Old May 15, 2003 | 08:28 AM
Torres's Avatar
thanx 4 the offer but i'm goin' 2 do it at work.....
i'll post up if there is a problem when i install it on my Max
Torres
Old May 15, 2003 | 08:36 AM
D-sta's Avatar
Yeah there shouldn't be a problem by welding it.
Old May 15, 2003 | 09:05 AM
Torres's Avatar
cool thanx 4 the help guys.....i was scared that it wouldn't work......
one more thing.......and i can't remember if there is any gaskets 4 the flanges of the y-pipe and cat?????
Old May 15, 2003 | 10:21 AM
timmyrig89's Avatar
yes probobly have to get the y pipe to manifold gaskets at the dealer since they are crush rings but the y pipe to cat is just a normal gasket you can get at any auto parts store
Old May 15, 2003 | 10:34 AM
Michael's Avatar
Back in a 3rd Gen.
I got a set of the crush rings from autozone a while back for the 90 I had.
Old May 15, 2003 | 11:13 PM
Torres's Avatar
cool thanx 4 the info......well 2day i got the y-pipe weled at work and my friend did a great job on it..... so 2morrow morning goin' 2 the shop and install the y-pipe on and c how it sounds
thanx 2 everyone 4 the help
Torres
James92SE
142
Jan 2, 2024 09:23 AM
Andy29
Sep 29, 2015 05:32 AM
msellas
Sep 23, 2015 09:16 PM
