door lock timer question
Old Jun 3, 2003 | 12:59 PM
Menel's Avatar
1992 Maxima SE
im not seeing anything damaged on th edoor lock timer to repair....*confused*
Old Jun 3, 2003 | 02:37 PM
Matt93SE's Avatar
STFU n00b!
resolder all the connections. whether they look bad or no, they probably are in a few places.
Old Jun 3, 2003 | 02:55 PM
Menel's Avatar
1992 Maxima SE
thanks!
but at the same time..damn!..thought it would be a 2sec job....guess ill be breaking out the solder station
Old Jun 4, 2003 | 07:42 AM
Matt93SE's Avatar
STFU n00b!
it takes me about 10 minutes to fix one. it's not that big of a deal.
Old Jun 4, 2003 | 10:38 AM
KLoWnPR109's Avatar
I might be retarded, but where is the door lock timer? I haven't had the energy to work on my car for the past three days so I haven't been able to check. Haven't even made it outta bed
Old Jun 4, 2003 | 12:18 PM
ghostmax's Avatar
it's in the driver's kick panel to the right of the steering column in a black box, held in by 2 screws. i believe it has two harness going into it.
Old Jun 4, 2003 | 12:50 PM
D-sta's Avatar
I think on some of them they are not there. I went to my neighbors 91 SE thinking it would be there and it wasn't but his door locks worked and I was thinking it was located somewhere else. On my 92 it was right there on the ride side of the steering column.
Old Jun 4, 2003 | 03:17 PM
Menel's Avatar
1992 Maxima SE
one of the connector pins had very little solder on it. but i used a dmm and there was a connection through it..but i resoldered it anyway
then I heated up all the solder on the bottom and let it redry
not working, can't see anything wrong with it, broken, nothing. looks fine. but i have that problem where i press the locks and i hear the click behind the dash, yet the locks don't work.
once i get through with putting car in the shop due to being rear ended (see my othe rthread) i might send it to to you..i checked nissan awhile back adn they said 113 for a new one!!
Old Jun 4, 2003 | 10:22 PM
Matt93SE's Avatar
STFU n00b!
use a solder sucker or some solder wick to remove all of the old solder first, THEN re-flow all the solder onto the joints. I haven't had a single one need more than that yet. I've replaced the capacitors and some other stuff in them just to be safe, but they've never needed it.
Mar 12, 2020 12:06 AM
Johnny9595
Sep 3, 2015 05:18 AM
Hailstatejig
Sep 2, 2015 06:52 AM
