Need detailed instructions on installing Tokicos shocks in San Diego
Old Jun 3, 2003 | 11:10 PM
va1adez's Avatar
I need all the help I can get guys. I work on a military installation so I have access to a variety of tools. I need detailed instructions with pictures please. I am not mechanicaly inclined so all the help is very valued. Thank you.
va1adez@***.net
Old Jun 4, 2003 | 12:04 AM
nubiannupe's Avatar
OG Maxima.org Member
Someone here just did an install with pics. I'd have to look a bit deeper to find out who, but give me a sec...
Old Jun 4, 2003 | 05:57 AM
e_is_chillin
I just did my springs p.5 There you'll find some useful links. Good luck.
Old Jun 4, 2003 | 06:00 AM
D-sta's Avatar
you can also use the write-up at www.4dsc.com
Old Jun 4, 2003 | 06:20 AM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
exactly what you need
http://www.4dsc.com/articles/suspens...h_tokico.shtml
Old Jun 4, 2003 | 04:09 PM
todamax's Avatar
Re: Need detailed instructions on installing Tokicos shocks in San Diego
I guess the first step would be to go to San Diego.
At least for me anyway.
Old Jun 4, 2003 | 05:40 PM
va1adez's Avatar
Help
I was looking at the directions on WWW.4dsc.com and it is very broad for me. I am not mechanically inclined so I guess thet explains it. I am going to do this on a military base. I will be able to rent out a port and have access to all the tools I need. Here are the questions I have:
1.How long is the front and back going to take?
2.Are sway bars easy to put on? A little tight on money but if it
is easier to install it I will wait. If not, I might as well
purchase one now and install it, your opinion?
4.Shocks, I do not know how they look because I just ordered them. Do
the front need to be inserted or will I mount the whole Tokico
strut.
5.The back are inserts right?
Thanks for the help.
Old Jun 4, 2003 | 08:33 PM
ghostmax's Avatar
Re: Help
strut.
Fronts you will replace, rears are inserts. Don't know how long it takes since I haven't done them yet.
Old Jun 4, 2003 | 10:34 PM
todamax's Avatar
If everything goes well, you can do the whole thing in 4 hours. I didn't have any issues with the fronts on either car that I did. The rears were a bite. On a '93 GXE I broke the wheel cylinder bleeder bolt on reassembly. I ended up replacing both wheel cylinders. On my '89 GXE the left rear gland nut was frozen on. I ended up using a dremel with a cutting wheel and an air chisel to get it off. It was 3 days before I got that side back together. The right rear I had done in 40 minutes.
Old Jun 5, 2003 | 05:52 AM
DaBoxSE's Avatar
sounds like we should have plenty of WD-40 when we do this
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
Violator
Sep 9, 2015 10:14 AM
16_SR
Sep 7, 2015 06:47 AM
maxfever1987
Sep 6, 2015 06:20 PM
