Installing Side Marker Lights
Old Jun 25, 2003 | 03:13 PM
1swtMaxima's Avatar
How do yall install side marker lights. The Universal ones like where do they, the wires I mean, and what should I hook them up to. I need to know before a near by meet wit sum maxs
Old Jun 26, 2003 | 06:55 AM
nismo1989's Avatar
Re: Installing Side Marker Lights
Wire them to the turn signals. You will have to cut a hole in the fender...
Old Jun 26, 2003 | 01:36 PM
1swtMaxima's Avatar
nd howo u gto that
Old Jun 26, 2003 | 01:44 PM
Michael's Avatar
Back in a 3rd Gen.
nd howo u gto that
not sure what that says but if you are asking how to do it then you drill a hole in the fender the size it needs to be for the part of the corner light that goes through the fender (probably a small hole for just the wire or something.
Then you take a test light and find which wire on the turn signal that is the supply wire (not the ground wire) and tap into that.
If this is confusing to you I suggest you get someone else to do it for you.
Search around there is probably a how to somewhere on it.
vingodine
45
May 21, 2016 12:46 PM
rtirbany
Sep 8, 2015 11:46 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
98nismomax
Aug 13, 2015 12:44 PM
papo99
Aug 9, 2015 07:32 AM
