Im up to my 3rd alternator... soon to see a 4th >:o
Old Jun 30, 2003 | 07:47 PM
Maximan190's Avatar
Alternator #1 - oem alt died around feb this year, this was that whining noise problem i posted about this past winter
Alternator #2 - got a "rebuilt" one from a parts store, that died around late may
Alternator #3 - the oem alt from my parts car, which is now on its way out
all 3 followed the same symptoms... the whining noise develops as the alt starts crapping out and without the alt to supply charge to the battery, the battery eventually dies
now i might have a few ideas i can try, but would like additional thoughts..
in case this may be a source of troubleshooting; which i somewhat doubt due to its inconsistency........ on alt #1, i ran my stereo (subs + 600w amp) about 5-6 months before it died. On alt #2, i had my stereo in for only about a month, but that still died 4 months later. On alt #3 i now have my stereo back in and its dying
i keep going through alternators in this car like gas
Old Jun 30, 2003 | 07:58 PM
D-sta's Avatar
Maybe its the sound system.....lol. Thats weird on how many alternators you've been through. Another question to ask Jeff.
Old Jun 30, 2003 | 08:11 PM
MrGone's Avatar
i had 500 watts on my stock altenator. I believe Matt93SE is using his stock altenator, and look at his amp rack
Didnt the one you purchased come with a warrenty?
MrGone
Old Jun 30, 2003 | 09:30 PM
bonzelite's Avatar
Re: Im up to my 3rd alternator... soon to see a 4th >:o
yes, matey, i had the same problem. exact same problem. what i discovered was that my amp, a big kenwood unit under the passenger seat, was draining my battery as it never actually "shuts off." a mechanic realized this, and we still do not quite know why. but he diconnected it, as i had a phat cable running from it to my battery. next, since all of the batteries died along with the alt (hint: expennnnnnssssssivvvvvvve), i replaced it with a solid as a rock AC Delco unit, and replaced both battery cables with fresh new ones, and regrounded the whole system to factory spec. now i have a stout battery, no corrosion or frayed lines, grounded to spec and a big smile.
result >>> no amp, but great reliable car. and no more alternators.
my two cents.
Old Jul 2, 2003 | 11:08 AM
propz''s Avatar
A bad ground wire can cause it to die . i went threw 2 of em till i replaced mine
Old Jul 2, 2003 | 12:43 PM
Matt93SE's Avatar
STFU n00b!
sounds like you need to change your listening habits also. do you listen to the stereo for long periods of time while the car is off? this can severely drain the battery, then the alternator has a horrible time trying to charge the system back up as soon as you start the car. this can cause it to overheat and blow up parts.
the whining noise... was it bearings or electrical parts whining? if it's bearings, another possible cause is you tighten your belts too much and cause it to ruin bearings... then the stuff in the alternator begins to self-destruct because of the extra heat produced by the bad bearings.
Old Jul 2, 2003 | 07:42 PM
Maximan190's Avatar
when the car is off i shut the amp off, so at most i only have the headunit/interior speakers on at times
the only belt ive touched since ive owned the car is the alt belt, (i didnt put on a UDP yet so i havent messed with all the belts) even the factory alt made the noise
Old Jul 2, 2003 | 10:04 PM
CandiMan's Avatar
Say Candyman 5 times
How about when idling
Do you bump your stereo when idling at long periods at a time (stop lights, parking lots, driveways, etc) Putting a heavy demand on a alty at constant low rpm isn't good. How about your power and ground cables, are they the proper size for "your" system? Wouldn't cables that are too small also put a heavy load on the alty, basically choking/starving the alty of that needed electron flow.
Old Jul 2, 2003 | 10:57 PM
Matt93SE's Avatar
STFU n00b!
Re: How about when idling
not necessarily. they will cause the system to draw a bit more current, but the biggest part that suffers from small power cables is the amp. in extreme cases, it can cause the whole system to supply more power, but not enough to cause huge problems--- unless you're running several thousand watts of power like me. (then again, I've got 193k miles on my factory alternator and have been running a 2500W stereo in the car for two years without a problem!)
back to the point........
wires have a finite resistance. small wire has more resistance than a big wire. (for an illustration, try blowing air through a tiny coffee straw, then get one of those big McDonald's straws and blow through it. BIG difference!)
there's voltage drop in the power cables due to the resistance in it, so if the amp is trying to put out 300W of power (assume the amp is 100% efficient.. it's closer to 35%, but we won't go there)..
Assume there is NO resistance in the cables.... the amp sees 12V.
300W/12V = 25A so the amp pulls 25A of current from the battery. no cable loss.
now assume the're 1.5V of voltage drop due to the small power cable.
300W/10.5V = 28.6A
so the amp has to draw MORE current from the battery to drive the speaker at the same power level... but the battery is still putting out 12V, right? (yes, I'm right. don't argue.) so that's 12V at 28.6A...
the battery is spitting out 28.6A*12V = 343W of power!
that's 43W more than the amp is using...
where'd that power go?
HEAT. it's literally cooking your wire. feel your power cables after the stereo has been at full power for a while. if they're more than slightly warm to the touch, then you need bigger cables.
Old Jul 2, 2003 | 11:12 PM
bonzelite's Avatar
matt,
that example/explanation of electricity is the best i have ever read or heard in my life as it demystifies the basic idea of current. wow. great job.
Old Jul 2, 2003 | 11:43 PM
Matt93SE's Avatar
STFU n00b!
Glad my EE degree finally helped somebody.
Old Jul 3, 2003 | 12:08 AM
bonzelite's Avatar
matt,
as i have been on here, i have read by now, of course, scores of posts from you, perhaps hundreds. and when i read that above one, i was like "holy sh*t, this is this guy's area of total dominance." you nailed that to the wall.
Old Jul 3, 2003 | 12:40 AM
Kennedy's Avatar
I bogged out in about a foot of rain that fell in 30 mins. It displaced my bushings which caused the alternator to die. I fixxed that, then it rained again and my alternator shorted out.
Any suggestions on a good replacement alternator?
Old Jul 3, 2003 | 07:41 AM
Matt93SE's Avatar
STFU n00b!
go to the parts store and buy an $89 replacement with lifetime warranty. and next time it rains, DON'T DRIVE THE CAR!
Old Jul 3, 2003 | 09:12 AM
Kennedy's Avatar
I wish I could do that. Here in Calgary we can have all 4 seasons in 20 minutes. Hell yesterday we had +25 celcius when I woke up at 9 am, then it dropped to about +5 celcius, then it hailed, rained and back up to about 28 by 2:30ish.
My maxima is my everyday driver and I'm not going to not drive it the rain, simply because I have to get places. I have a skirt on the bottom of my car and was thinking of moving my skidplate more towards the front of the car but I don't know if that would be such a good idea. Leaving the oilpan exposed and all.
Old Jul 3, 2003 | 10:57 AM
Matt93SE's Avatar
STFU n00b!
water will still get around the skidplates and whatever covers are down there. if you MUST drive through high water, then do it slowly. you can't just bulldoze through it like your car is a 4x4. if you do, expect to keep replacing alternators. it's that simple.
Old Jul 3, 2003 | 11:03 AM
Kennedy's Avatar
I went through at maybe 15 KM/H. =\ Water was just too high I guess.
Old Jul 3, 2003 | 11:10 AM
Matt93SE's Avatar
STFU n00b!
if you're going to go through deep water like that, you need to slow down WAY more than that. like 2-3mph (3-4KPH) maximum.. any splashing at all will cause it to dunk the alternator, then you're skrood.
Old Jul 3, 2003 | 12:17 PM
Kennedy's Avatar
I realize this now =\
I also think the water was that deep. I almost stalled out. =\
Old Jul 3, 2003 | 12:29 PM
Matt93SE's Avatar
STFU n00b!
Maxima != Off-road vehicle. If the water is that deep, then you're no longer technically on a road.. you're driving through a lake. stop the car, back up, or shut it off.
Otherwise, we'll start to call you Russ.
Old Jul 3, 2003 | 03:16 PM
MrGone's Avatar
i used to off-road in my max, and I know I'm not the only one
Old Jul 3, 2003 | 09:14 PM
Matt93SE's Avatar
STFU n00b!
I off-roaded mine once..... and it cost the insurance company $3700, while I got to drive a rental car for 6 weeks while it was being fixed.
Old Jul 3, 2003 | 10:30 PM
MrGone's Avatar
was that the time you got your really cool sig pic and almost ran over another member or something?
Old Jul 4, 2003 | 12:15 AM
Matt93SE's Avatar
STFU n00b!
no... I'd been at a party until 3am, after working a 14 hour day at work.. I'd had a couple [dozen] beers and "nodded off" while driving home.. parked it in a drainage ditch about 50 ft from a river. I'm lucky to be alive at this point.... only thing that kept me from sinking the car in the river was hitting a tree stump buried in the mud.
James92SE
142
Jan 2, 2024 09:23 AM
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
worldwiderecognized
Sep 24, 2015 06:56 PM
lrb6805
Sep 24, 2015 05:03 PM
