95+Motor fit in 3rd gen?
Old Jul 1, 2003 | 07:01 PM
PRICEL$$'s Avatar
Please don't refer me to the search page, I have searched and found nada concerning this matter. I have a 92 VE and have all the typical problems it seems, VTC's and broken manifold studs, oil leaks, power loss. I was wondering can you swap the motor and ECU from a 95+. Will it bolt up to the stock VE tranny? If not is it possible to do the full swap with little modification to motor mounts, etc. If the 95+ is not an option how bout an SR20? I know I sound stupid but I'm used to Hondas and you can put just about any motor combo in these car no problem. Please help if you can.
Kari
Old Jul 1, 2003 | 07:09 PM
phast92se's Avatar
with alot of money any motor will fit... there are no direct swaps that i know of
Old Jul 1, 2003 | 07:15 PM
phast92se's Avatar
the VE has alot of potential anyways, jus "fix" your problems and do some modding and you should be happy with the end result
Old Jul 1, 2003 | 07:20 PM
JDwyer2821's Avatar
I think you will need custom mounting locations because the 4th and 3rd gen are differant. I am almost positive. Plus I think the tranny bolt pattern is differant
Old Jul 1, 2003 | 07:30 PM
shoult's Avatar
It'd be interesting if somebody could find a non-rebuildable front cut of a 222hp or newer Max with time and money to fab up the job. Then write it all up for a FAQ.
This is how it's been approached in the other car forums I'm in.
Old Jul 1, 2003 | 07:32 PM
phast92se's Avatar
it be hella bad is somebody could do that, but i dont see anybody actually spending that much time and money into a 9+ older max
Old Jul 1, 2003 | 08:05 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
a whole lot of info in this thread here-->
http://forums.maxima.org/showthread.php?threadid=229314
Old Jul 1, 2003 | 09:23 PM
dmontzsta
Old Jul 1, 2003 | 10:07 PM
Matt93SE's Avatar
STFU n00b!
SEARCH focker. there's a TON of info out there. don't gripe at me if you're too lazy to find it.
MAXSE5SPD
Sep 17, 2022 04:00 AM
mclasser
Sep 6, 2015 09:05 AM
