need help please!!
need help please!!
my bose head unit stopped working..i bought a new head unit but now i dont see any wiring diagram or anything to change the unit can someone pls help me with wiring a 92se head unit diagram..thanks
also the bose head unit antenna cord has 2 jacks and i cant find ant aftermarket head unit with the 2 how do you guys deal with that one
dont cut your factory wires!
go to a local audio shop and buy a harness or get one from wal mart. You will also need the adapter for the antenna. It plugs into the 2 prong one and has a standard out.
the harness you buy will have the directions on it to connect a new radio up.
Listen to awsm66. Even if you dont care about cutting factory wires, It is soooo much easier to have the harness. you can wire it up while sitting on your couch if you wanted to (or on the way home from the store
) unhook one clip and get instant mobility vs. being stuck right next to the dash cutting wires and doing a ****ty job at it.
MrGone
) unhook one clip and get instant mobility vs. being stuck right next to the dash cutting wires and doing a ****ty job at it.MrGone
damm...i had already cut the damm wires man this thing is the hardest i ever did so far my other max i install the system my self and it was totally different...so i cut the wires already any other ways i could do it with the wires already cut
Now the wire is in factory shape and go and buy a harness. The harness is labeled to where the wires need to go on your radio. connect them up using the solder method above. Then go plug it up to the factory plug.
if you cant solder then buy white caps or butt connectors and use those instead of soldering.
if you dont have the plug that you cut off then the correct thing to do would be go to a junk yard and cut one off of another max and hope that the wire code is the same (should be).
If you still just want to hook up your radio and not do it the right way then do a search on here using my name and harness (or something) since I posted a while back the wiring of the radio. It may have the color code for the wire too...not sure on that though.
good luck,
I installed an aftermarket stereo on my dads 87 maxima and could not find an adapter harness kit anywhere. So I had to pull out the wires from the harness, got myself a wiring diagram from the haynes manual and i connected everything together by wrapping the wires and then putting some electrical tape to hold it together.
You just have to be careful to separate your wires properly like the live wire that has voltage, the grounds, and the wires leading to the speakers. This job is intimidating the first time, but its well worth being careful and taking the time so you dont short anything.
hey guys thanks for the help....i finally figured it out by testing all the wires and all and then get everything hooked up...it sounds real good too..but in a few weeks am getting a real system and changing those bose and all that but thanks again yall
