What weight did you input for your car when using G-Tech Pro
Old Feb 2, 2001 | 09:13 PM
CandiMan's Avatar
Say Candyman 5 times
From reading the instructions I came up with a total weight of 3,710lbs. Should it be higher or lower. Trying to get base line numbers to compare to future mods.
Old Feb 2, 2001 | 10:35 PM
primeevil711's Avatar
door panel
Try checking the inside door sill. There is a metal plate there with some weight specs in both metric and english standards, I've seen it on my car but I don't know if you still have it on yours ( I don't have a G-tech so I don't know how accurate you can get with the device) Tell me if the G-tech is worth the money or accurate as far as your car goes.
Old Feb 3, 2001 | 12:54 PM
Nismo87SE's Avatar
Just do about +/- 50lbs of the curb weight listed for your car. At the track I weighed my maxima and it was 3210lb without driver and 3355lb with driver. I believe you should try around 3350-3400lb.
Old Feb 3, 2001 | 01:25 PM
CandiMan's Avatar
It said to take the GVW (which is usually fully loaded, 5 passengers, etc.) and minus 180lbs for each passenger that isn't there. From doing this I came up with my weight 3,710lbs. Does the GVW include a full gas tank, I think so. If so, it just so happen that I had a full tank when I did a initial run. Primeevil, I have yet to have an opinion on the G-Tech pro. Kinda hard to find a level road out here without the worry of getting busted. But if you're the type that likes to mod and curious of the outcome, why not.
Old Feb 4, 2001 | 12:58 AM
Bryan H's Avatar
3150 for a 92 se 5spd
well mine at least
Old Jun 3, 2002 | 08:37 PM
MrGone's Avatar
i use 3360
or just 3300, sometimes 3160, i cant quite remember
generally i use anything between 3100-3300, just because its easier, remember, the lower the weigh the worse times youll get. which is good because youll be happier on the track.
i actually dont use it much anymore, when i use it for serious accurate times i use the exact weight and run the same street to keep it all fair.
MrGone
Old Jun 3, 2002 | 08:40 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
why are you bringing back a 1+ year old thread thats already been answered???
Originally posted by MrGone
i use 3360
MrGone
Old Jun 3, 2002 | 09:26 PM
Sudesh's Avatar
Sorry for pw'ing, but i had to
Old Jun 4, 2002 | 11:59 AM
Nismo87SE's Avatar
WTH?? I knew this thread was old just by looking at the title. Some archiving is ok but damn, even I might be annoyed
i use 3360
MrGone
Lakersallday24
Jun 16, 2019 01:35 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
acw
Aug 7, 2015 04:20 PM
