HELP!!!! Parking lights not working!!!!
Old Jul 20, 2003 | 11:48 AM
youngbleek85
Ok this is the run down. I had the washer jet led lights hooked up to my parking lights and last night i decided to replace my parking lights with hyperwhite bulbs and my signal lights with plasma blue bulbs. I put the new bulbs on the left side of my car and everything ws working fine. And at first when i put them on the right side everything was working fine and then like 30 secs later both parking and signal lights stopped working on both sides and now i can't get them to come back on. I disconnected my LED washer jet lights because i thought that they might have something to do with it but My lights still don't work. My Headlights work perfectly with the hyper white bulbs. Can some one please give me some advice.
Old Jul 20, 2003 | 12:53 PM
reggaeboyz's Avatar
check your fuse and see if any of them are blown
Old Jul 20, 2003 | 01:01 PM
youngbleek85
How can you tell you tell if the fuse is blown. And if they were then how would i fix that?
Old Jul 20, 2003 | 01:23 PM
AscendantMax's Avatar
it's most likely the fuse is blown. take a look on the top part of the fuse. on a good fuse you should see a strip of metal connecting the two prongs. the strip is burned/disconnected on a bad fuse.
Old Jul 20, 2003 | 01:47 PM
youngbleek85
thanx
Old Jul 20, 2003 | 01:49 PM
youngbleek85
Ok you have to walk me through this because i am new to this. Where is the fuse and what do i do if the fuse is blown?
Old Jul 20, 2003 | 03:07 PM
replace the fuse. take a look-see in your maxima owner's manual or here . not to be rude or anything, but this is fairly simple thing to do. you won't know how to do if if i guide ya all the way through. get your hands dirty!
maxinout93
Oct 27, 2015 01:29 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
kenc15
Aug 5, 2015 08:29 AM
kjm900r
Aug 5, 2015 07:14 AM
