Bellow Boot? Rack & Pinion? WTF?
Old Jul 23, 2003 | 03:40 PM
|Bijan|'s Avatar
UCF Lexus
Dude, my car is such a....you know.
I took it to have a Vehicle Inspection from Firestone today and they said my Bellow Boot had a huge hole in it and I saw it from underneath when they lifted my car.
They say my rack and pinion assembly is leaking...(leaking what? - PS fluid?)
and a hella other shiiat.
Are those 2 things DIY? Also, what about changing the master cylinder...how hard is that?
Old Jul 23, 2003 | 04:12 PM
Aaron92SE's Avatar
NWP Engineering.com
Re: Bellow Boot? Rack & Pinion? WTF?
Bellow boot... aka rack and pinion steering rack boot. Those things crack easy with older cars. And if they are exposed, dirt can get up in the universal joints and hurt them. It's just not good for that nice clean grease to get dirty. So, replacing them is good. GET OEM ONLY!!! I got cheap $7 boots from AutoZone and they cracked 1 year later. ****ES me off. It took me 3 or 4 hour to do both sides AND I needed an alignment. Get a quality boot!
But as for your rack leak... yes, it's PS fluid. And I HOPE it's not coming from the rack itself. For me, my PS resivoir was leaking from a hose and it would get on the crank pulley and it would sling all over the engine. And it would drip from a certain screw that was underneath the rack. So of course, mechanics want to charge $600 for replacing the steering rack. I'm like, sorry... NO WAY.
I found the problem myself and fixed it. But that doesn't mean your rack isn't leaking. Just be sure about it. I think a refurbished rack is around $300. Then, another couple/few hundred for labor.
I don't know too much about the master cylinder. But changing your rack, it not really something you'd like to do in your driveway in your back.
Old Jul 23, 2003 | 08:56 PM
|Bijan|'s Avatar
UCF Lexus
Well I just recently replaced my PS pressure hose...it busted for some odd reason, but I've never had my PS go out on me. The bellow boots is more toward the driver side...I can touch it from the top of the engine bay...(kinda under my master cylinder)
Old Jul 23, 2003 | 11:30 PM
MrGone's Avatar
it could be worse....
http://mrgone.homeip.net/images/steering/
Listen to Aaron though, the boots arent fun to replace on a rack and pinion.
btw, my problem is that everytime I turn the wheel to make a right hand turn, the pressure line makes its way towards the manifold (that is cracked). One of these days I'm just going to get fed up, and rip the exhaust off, put some long tubes on, reroute the PS lines, and clean the thing. Plus rebuild the whole "rack". oh, and re-route my ignition wires.
Old Jul 24, 2003 | 07:25 AM
Matt93SE's Avatar
STFU n00b!
I was sitting here thinking "what kind of f***ing moron would put a power steering hose there?!?!"
Then I realized the engine was Ford Blue...
Old Jul 24, 2003 | 08:21 AM
|Bijan|'s Avatar
UCF Lexus
lol - that looks like a burn in ths PS hose...
MrGone...both of our udercaraiges look the SAME! it's sad
Old Oct 24, 2003 | 09:51 PM
Jaybird180's Avatar
How was it for the driver's side boot. Mine is separated. Is there a "quickboot" for this?
Old Oct 24, 2003 | 10:41 PM
Aaron92SE's Avatar
NWP Engineering.com
Since you're from NC, I will help you out. I have heard of a "quickboot", but it's worse than the AutoZone boots I put on my car. Basically, it's a boot that is split down the side and you are able to wrap it around the joint on the rack and then you're set. It's a cheap and easy fix. But you will have to find some kind of universal boot b/c I seriously doubt they make this quickboot strictly for the Maxima. Just be prepared to have them come lose or tear a year later.
If you can find them, then, sure why not. It's easy. But if you wanna do the job right, I only recommend quality Nissan parts.
Old Oct 25, 2003 | 03:22 AM
nubiannupe's Avatar
OG Maxima.org Member
..... if you wanna do the job right, I only recommend quality Nissan parts.
...and he not only says this because he's a client, but because he's the president!
But seriously, get the OEM boot. You won't be sorry.
Old Oct 25, 2003 | 06:20 AM
drstillpatient's Avatar
how many hours of labor would this boot replacement cost at a shop ? one boot only
Old Oct 25, 2003 | 11:11 AM
Aaron92SE's Avatar
NWP Engineering.com
I'd have to estimate one boot replacement for a shop to be 1.5 hours of labor. Then add an alignment to that. Since you're getting the alignment done, might as well change both boots.
As I said above, my boots are cracked right now b/c I went with the cheapo AutoZone boots. They were universal so I had to cut them on the correct scribed lines. They ripped in less than a year. That sucks.
Old Oct 25, 2003 | 01:00 PM
|Bijan|'s Avatar
UCF Lexus
Thats what my problem was. But...the car is sold.
Old Oct 25, 2003 | 01:16 PM
MrGone's Avatar
Dude, your engine bay was dirty!
I've got the same problem on the mustang, but it should be alot easier/cheaper to fix.
Old Oct 25, 2003 | 04:13 PM
|Bijan|'s Avatar
UCF Lexus
13 yrs old....just think how dirty you would be if you only had like 3 baths....
Old Oct 25, 2003 | 04:24 PM
xdannyx25's Avatar
i have the same problem, but not as bad, its a tear on each boot. what is it i need? only the boots? can i replace it by just uninstallign the outer tierods and sliding it in and out? do i need grease?....
Old Oct 25, 2003 | 05:46 PM
Jaybird180's Avatar
And I JUST had some front end work don when I had my tranny swapped. They replace the pass side 1/2 shalf, THEN after putting car back together noticed the boot.
Old Oct 26, 2003 | 01:50 PM
|Bijan|'s Avatar
UCF Lexus
People have told me it is a B|TCH to change. Not just the whole rack, but the boot too.
I dunno much about it apparently....wish I could help yall out more.
Old Oct 26, 2003 | 02:03 PM
King King's Avatar
I had the same problem with my max.
My max seems to be leaking oil though. All of the parts around it a being eaten away.
I found this out about five months ago and still haven't fixed it and verything still works fine for now.
Old Oct 27, 2003 | 03:54 PM
xdannyx25's Avatar
how much do oe boots cost?
Old Oct 27, 2003 | 04:19 PM
Jaybird180's Avatar
My local dealer wanted $25 and change. Next nearest dealer was $20.88, but I had to order locally.
Old Oct 27, 2003 | 04:24 PM
xdannyx25's Avatar
thanks___________
Old Oct 27, 2003 | 06:52 PM
anaximander's Avatar
I watched the mechanic change my R&P in 2h.
Old Oct 27, 2003 | 06:59 PM
internetautomar's Avatar
mod or sell?
I'm sure he was thrilled with that
Old Oct 28, 2003 | 12:26 PM
crsmax's Avatar
I currently have the same problem, and have noticed all of these things after an inspection at NTB, in which I also had to get my front wheel bearings replaced... I also have a cracked R&P busing that is loose off of the bracket. Does anyone know how much for this bushing to be replaced?
Old Oct 28, 2003 | 01:03 PM
Jaybird180's Avatar
Ahhhh What's R&P guys?
Old Oct 28, 2003 | 01:35 PM
MrGone's Avatar
Rack and Pinion. first time I've seen it called an R&P aswell. Laziness is bad
Old Oct 28, 2003 | 02:44 PM
Explain yourself rolling eyes.
Old Oct 28, 2003 | 04:01 PM
mod or sell?
Most mechanics as well as any other service personel don't care for people watching them while they work.
Old Oct 28, 2003 | 04:47 PM
He is a friend of mine. How else are you going to learn if not by watching? Or are you one of those guys that go by the book and end up in deeper feces than before the repair?
Old Oct 28, 2003 | 06:08 PM
Pervis Anathema's Avatar
Yep, if they watch, then you can't gouge them on labor costs because they will know how long it took. And to top it all off, you can't cut corners. Blasted customers.
Old Oct 28, 2003 | 06:54 PM
xdannyx25's Avatar
well that depends some dealerships have set hours, even if he does a 2 hour job in 45 mins he gets paid for the 2 hours
Old Oct 28, 2003 | 07:28 PM
mod or sell?
I'm not a mechanic. I happen to know ALOT of them though and it ahs nothing to do with cutting corners or gougeing it has to do with being comfortable. I'm not comfortable with people staring over my shoulder when I'm working a computer (stopped doing it for just that reason). Sheeeet I don't like people looking over my shoulder when I'm looking up parts.
Old Oct 28, 2003 | 07:33 PM
Well, I wasn't literally "over his shoulder". Just observing the steps in the process. Being that he's a buddy of mine, he understood as that's how he learned to fix cars himself. He doesn't have any diplomas but I trust him more than the "certified mechanics".
Old Oct 28, 2003 | 07:50 PM
mod or sell?
I wasn't refering to your case in particular just most cases.
I literally look over my mechanics shoulder.
But then again he has to put up with me, I'm the boss's nephew
Old Oct 28, 2003 | 09:29 PM
Spoiled *****.
Old Oct 29, 2003 | 06:23 AM
mod or sell?
Spoiled *****.
Jealous?
And I work for a parts warehouse
Old Oct 29, 2003 | 07:34 AM
Jealous?
That question is in itself answered by the mere fact that I can't even find a solid SE in a million people city..plus two totalled maximas in 3 months.
Old Oct 29, 2003 | 07:42 AM
mod or sell?
PLZ try learning how to drive before you buy your next max. There are so few good one's left as-is we don't need any more destroyed!
OK so i'm 1/2 joking
Old Oct 29, 2003 | 06:27 PM
There's little you can do, no matter how good you drive, when someone makes a sudden U-turn in front of you instead of actually merging into your lane. But your point had already been digested by my mind before you brought it up. There's a part of my driving that I largely ignored and that is anticipation. Instead of counting on other people to realize and correct their mistakes, I'm much more observant and patient than before. I extrapolate situations now and try to contain my aggressive driving nature, especially in busy traffic and with suspiciously behaving drivers.
knight_yyz
Nov 1, 2015 01:34 PM
fastcarny
Oct 12, 2015 07:06 AM
06maxima55
Sep 28, 2015 04:29 PM
londonflu
Sep 19, 2015 02:33 PM
