I want your opinions on mounting a set of crossovers
Old Feb 5, 2001 | 08:01 PM
ngthing's Avatar
I have a component set and I want to stick my crossovers in the trunk with my cap and two amps. how would i go about doing this? would I just run my speaker wire from the back trunk to the front?
Old Feb 6, 2001 | 08:51 AM
ray89se's Avatar
thats a lot of work
from ur amp to the crossover then u need 2 sets of speaker wire goin to the door then pass through the wire boot... pain in the ***.... can be done.... my crossovers r in the door
Old Feb 6, 2001 | 10:30 AM
Chris Gregg's Avatar
Get Off My Lawn
I had Kicker X-overs for the front and placed the one on the driver's side up under the dash and wire tied it in place with some other wires and wrapped it in a small peice of carpet to avoid shorting/ grounding out. The one on the passenger's side I put inside the kick panel. Kicker X-overs are relatively larger and longer than most others I've seen, you should have no problem finding a place. Like said before, just put them in the door! How about mounting them on the back of the Bose Box in each door? Should be plenty of clearance!
wyobbagy
Jan 3, 2023 12:03 PM
dvcamp
Sep 18, 2015 10:17 AM
240tomax
Sep 13, 2015 03:28 PM
spidgeon
Sep 9, 2015 03:36 PM
