Building Turbo Max Se
Ok, guys I am gonna need some help on this one. I am working on the internals of my VE getting it ready for some BOOST. I am looking to get these parts prior to the teardown and rebuild. I will probably be getting most of this in mass order from courtesy nissan. But if you guys know where to get it cheaper or even a affordable performance part for it I would appreciate it.
87mm Dished Pistons
Injectors - I have heard I can get better performance through a 300zx injector?
Knock sensor and the harness from the TSB.
Head Gasket Set (Upper set)
Lower Gasket Set
Water Pump
Piston Rings
Main Bearings
Rod Bearings
VTC Rebuild Kit x2
Thanks Guys
Steve
Peerless Performance
87mm Dished Pistons
Lower Gasket Set
Water Pump
Piston Rings
Main Bearings
Rod Bearings
VTC Rebuild Kit x2
Thanks Guys
Steve
Can you PM, Email or AIM me more info and pricing on the Poly Urethane Bushings?
As for the internal engine parts, where have you found the Dished pistons? I ask because I've never seen any after market VE specific pistons before, and if you use them from a VG, they will fit, however you will have to use VG connecting rods, but since they will fit, thats very good news for you.
MrGone
MrGone
Re: Building Turbo Max Se
Besides the dished piston your your "internal boost prep" appears to be for a OEM rebuild instead of a rebuild geared to boost. But new rings and bearings are always a plus regardless if it's for OEM or boost. Are you planning the rebuild yourself or are you getting the parts for someone else to build.
87mm Dished Pistons
Lower Gasket Set
Water Pump
Piston Rings
Main Bearings
Rod Bearings
VTC Rebuild Kit x2
Thanks Guys
Steve
87mm Dished Pistons
Lower Gasket Set
Water Pump
Piston Rings
Main Bearings
Rod Bearings
VTC Rebuild Kit x2
Thanks Guys
Steve
everything else get from the dealer with the lowest price..but like was mentioned above, you cant order rings/bearings until the motor is apart and measured.
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
