Caster angle off after Eibach Drop
Old Aug 19, 2003 | 06:30 PM
mikesmaximase's Avatar
If Anyone has had trouble with their caster alignment after they lowered their maxima please let me know. Sears told me they couldn't adjust the caster and its off a little so that it pulls slightly to the right. They told me I have to goto a frame shop and have them bend the strut. To me that doesn't sound right. Let me know what you think. Thanks! I know there isnt an adjustment at the top of the struts. I had it aligned 1 month before the springs and it was fine, but with the shorter springs it has thrown off the angle, if anyone knows how to fix it please let me know. Mike
Old Aug 19, 2003 | 07:24 PM
todamax's Avatar
I've dropped 2 maximas with Eibachs and neither has had alignment problems. Both were dead on. Take it to a private shop.
Old Aug 19, 2003 | 09:21 PM
DanNY's Avatar
Ad·min·is·tra·tor
caster?! that's not usually off.
perhaps your CAMBER is off after drop..not caster unless you have a bent control arm, worn control arm bushing, or got into an accident.
Old Aug 21, 2003 | 04:22 PM
No its not the camber its the cross caster angle. They checked, and I checked out my control arms and bushing and all was fine with those. The car has never been hit before.
Old Aug 21, 2003 | 08:07 PM
Matt93SE's Avatar
STFU n00b!
they're pulling your leg. take it to a different shop.
Old Aug 23, 2003 | 09:08 AM
I have a print out of the alignment. My Caster angle is 0.4 degrees for the front left and is supposed to be set at 0.5-2.0 degrees. The front right is set at 1.0 degrees and is supposed to be 0.5-2.0 degrees. The Cross Caster angle is -0.6 which is what Sears said is causing the drift to the right. ??????????
Old Aug 23, 2003 | 12:17 PM
Matt93SE's Avatar
STFU n00b!
caster won't cause a drift, unless you've got other problems causing the car not to sit at the same ride height on both sides. caster is a measure of how much your strut leans forward or back. it shouldn't mess too much with the car drifting left or right.
Old Aug 23, 2003 | 01:12 PM
Well I was thinking if the left side is to far forward then it would be pushing againt the right side and push it that way.
Old Aug 23, 2003 | 05:50 PM
Matt93SE's Avatar
STFU n00b!
not necessarily. I would check your struts and suspension bushings though. the ONLY way the caster can get messed up is if you're in a wreck or if your suspension bushings are worn.. if you car has over 100k miles and they haven't been replaced, then they ARE worn- whether they look like it or not.
Old Aug 24, 2003 | 07:21 AM
My struts I have just replaced. Which Im going to upgrade to tokico, If I dont buy my buddies 99GTP. I will no matter what replace the front bushing while Im installing the sway bars..
Old Aug 24, 2003 | 07:36 AM
DanNY's Avatar
Ad·min·is·tra·tor
do you know for a fact the car hasn't been hit?
are you the orig owner?
Old Sep 1, 2003 | 07:09 PM
Yes, I know the original owner. She is a friend of the family, it has never been in any accident accept for her sons motorcycle tipped over and hit the driver side rear door. Thats all.
Old Sep 6, 2003 | 07:23 PM
What about if one of the springs isnt sitting right. I know I lined them all up right. But Ill check it tomorrow. I just installed the front ST sway bar and took a look at the a-arm bushings and they didnt look to bad but Im still goign to replace them anyways. Ill let you know later how it came out.
Old Oct 25, 2003 | 08:15 PM
Ok they are gone, I got under there and gave them a good look when I was installing the plastic plating again. They are all torn up. So this wekend its a must that I replace them. Thanks Ill let you know saturday how the difference is.
trsandrew
Apr 8, 2016 06:45 PM
jonreidhead
Jan 6, 2016 09:38 AM
trsandrew
Oct 25, 2015 02:47 PM
maxima-junky
Oct 7, 2015 06:13 PM
Redfox
Sep 28, 2015 10:41 AM
