brake light problems
ok i drove the car out of the shop today and someone pulled up to me to tell me i had no tail lights. so i pulled over and checked. i have park lamps on in the taillights, but no actual brakes. i have current at the fuse, so what could it be other than a shorted wire?. im assuming the brake switch is good because i can shift out of park, or is the brake switch and the shift lock on another circuit? i havent really gotten to look into it since its dark now, i figured i would start getting some input in case i cant fix it
check the bulb wires themselves. i had that problem awhile back. the heat from the bulbs melted parts of the housing and the wires were fubared. hopefully you can just fix the short and not replace the whole light housing like me.
I think the stop light switch and the interlock switch are on different circuits. First thing you need to do is get a test 12v light. It will make things so easy.
1)Test for power at the switch. If not, test the fuse. If fuse is ok, your problem is before the fuse. You'll need a wire diagram.
2)If you have power to the switch try removing the plug from the switch and jump it with a wire. If the lights come on, it's the switch.
3)If not use the test light to check for power at the tail light plugs. If you have power, the housing is the problem. Don't forget to check the grounds.
4)If you don't have power you'll have to trace back to find the brake in the wire.
First things first, get a test light.
BULBS had the same problem have you been changing your bulbs lately???
if you put the wrong bulb inthe the socket it blows the fuse and stuff
does your gagues light up, if it doesnt then that is your problem the bulb in the tails and the fuse are blown
keep in mind i dont have 3rd gen tails anymore
the park lamps turn on(when headlights areon)as do all the other lights, my 3rd brake light doesnt work.
its the switch, i just have to get the car home so i can test it
ok so i parked my car next to the parts car to see the switches easier(dash is off on the parts car) there are 2 switches on both, but the shift interlock and the tail light work off the same switch. (im assuming the clicking noise i hear, followed by be being able to shift out of park is the shift interlock, right?)
so heres the deal. i hear the clicking go on all the time when i press the brake, and when i ground the test light and touch it to the red/yellow wire, it also clicks, but there is no power(bulb doesnt turn on. now when i connect 12 volt directlyto the red/yellow wire, and press the brake i get both the interlock to work and the tails to light up. fuse has power, switch is good, wiring is good, at least from the switch on. how could the interlock work and not the tails? could there be resistence in the wiring, only allowing enough power to kick over the interlock relay? thats the only thing i can think of. right no i just pinned in a 12 volt source to the switch to get it to work, but i dont wanna be missing something else. and what does that other switch do?
Have you checked to see if you have good ground????
tsi6001
Oct 3, 2022 10:23 PM
JMag90
Aug 25, 2015 09:17 AM
