TT Injectors
Old Aug 21, 2003 | 05:51 AM
male's Avatar
TT Injectors
I am searching but I thought I'd throw this out there...what are my otions for larger injectors that will pop in to the stock 89+ VG fuel rail. I will be starting my turbo build soon (out of necessity more than anything else..my engine is not doing so well, so I figured now's the time to get boost) and want to keep my Maxima style top end (heads, manifold, sensors etc). My plan is to use a VGT bottom end (for its pistons/C.R., high vol oil pump), keep the rest Max, go bigger injectors in the stock rails, Walbro or TT fuel pump, and hook up an FMU to deal with the injector pulse adjustment. T4 turbo right off the bat. That should be a good start. I have most of it worked out, but I would like to keep theinjector swap a bolt up affair if possible. SO question is, what injectors fit our rails? Again, I am searching so don't flame, just trying to cover all the bases and get the best info I can..
Old Aug 21, 2003 | 11:46 AM
MaDMaX024's Avatar
Re: TT Injectors
if you find out they do fit (which i'm pretty sure they will) email lowmaxima, he has a set for sale..or if hes already sold 'em, try john@z1motorsports.com, both good guys to deal with.
Old Aug 21, 2003 | 12:02 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
yes, 370cc TTZ injectors are a direct fit
Maxboy23
55
May 1, 2025 06:09 PM
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
msellas
Sep 23, 2015 09:16 PM
