Pcv Valve
Old Feb 12, 2001 | 04:35 PM
Lj90Se's Avatar
can someone tell me where the pcv valve is located.
Thank You
Larry
Old Feb 12, 2001 | 05:18 PM
fornimage's Avatar
The PCV valve is located on the intake collector...above the letters that say V6 3000...next to the coolant bleed valve....it's the fitting that one must unscrew in order to replace it. To check the operation of it, leave engine running, unscrew the valve and leave attached to hose. You should hear a hissing sound from the valve if it's working properly and if you place ur finger in front of the valve you should feel a strong vacuum. If not then time to replace it...no more than $3 and it's a good investment for the engine.
Old Feb 12, 2001 | 06:40 PM
Lj90Se's Avatar
Thanxs for the reply
It wasn't creating that vaccum, so I replaced it.
Old Feb 12, 2001 | 08:23 PM
fornimage's Avatar
Does it have that vacuum, now that u replaced it? Not to insult ur intelligence but was the car running when you did the test. Just make'n sure.
If no vacuum then I would check all ur vacuum lines for any leaks. Good luck!
Old Feb 13, 2001 | 10:58 AM
Lj90Se's Avatar
No prob
I would have asked the same thing,Yeah now it has a vaccum
Old Feb 14, 2001 | 12:37 PM
superdesi's Avatar
Re: No prob
Which "brand" of pcv valve did you install?
I installed a Purolator one and it did not seem to screw in properly.
Old Feb 14, 2001 | 12:41 PM
Lj90Se's Avatar
Genuine Nissan
part #11810-f0502 straigth from Courtesy $6.00+s/h
Old Feb 14, 2001 | 01:24 PM
superdesi's Avatar
Re: Genuine Nissan
Did they give you a discount?
If yes, how much was the the discount?
Their website quotes a different price.
Old Feb 14, 2001 | 05:53 PM
Lj90Se's Avatar
That was with the discount
I also ordered a couple of extra parts
TKHanson
Nov 24, 2018 01:39 AM
tseng1023
Oct 15, 2015 08:30 AM
hayne
Oct 5, 2015 11:53 AM
bumpypickle
Sep 20, 2015 08:22 AM
tardrex
Sep 11, 2015 07:35 PM
