suspension techniques swaybars!
Old Sep 14, 2003 | 12:27 PM
jkmay01's Avatar
Lil 8
I needed the know the big difference in the effect of the diameter of the front sway bar by suspension techniques? is it the bigger the diameter of the bar the better or quicker response you will get?? either a Sway Bar - Front - 1 1/4" Diameter , or Sway Bar - Rear - 3/4" Diameter I already have on the rear, but not to sure of the size want to say 1/4 inch let me know?? what one to go with???
Old Sep 14, 2003 | 01:43 PM
LittlePiggie's Avatar
go with the ebay fstb. cheap and it works wonderfully
Old Sep 14, 2003 | 03:35 PM
todamax's Avatar
Holy crap I have now idea what either of you are talking about - so here is random info:
How to make silly putty
S.O.S. pad info
Old Sep 14, 2003 | 03:38 PM
todamax's Avatar
oh and lets not forget this gem of info.
Old Sep 14, 2003 | 05:03 PM
Matt93SE's Avatar
STFU n00b!
the Sus Tech sway bar is the same diameter as the factory bar, but it's solid. the factory is hollow- weighs about 8 lbs. the Sus Tech bar weighs about 25 lbs.
much stronger.
as a general rule, the larger the diameter, the stiffer the bar is going to be. in the case of hollow bars though, all of that goes out the window. they can be hollow, solid, thick wall, thin wall, etc etc etc.
Old Sep 14, 2003 | 07:53 PM
jkmay01's Avatar
Lil 8
much stronger.
so matt i should go with the 3/4 inch sway bar then?? for a better responsiveness? compared to the 1/4 inch diameter bar??
Old Sep 15, 2003 | 01:40 PM
Lordrandall's Avatar
I belive that ST only makes one front sway for our cars. Same size as stock.
Old Sep 15, 2003 | 01:47 PM
jaguax's Avatar
lol todamax wtf?
Old Sep 15, 2003 | 06:56 PM
todamax's Avatar
Originally Posted by jaguax
lol todamax wtf?
yeah, I was in a sour mood.
Suspension Tech Rear Bar is 3/4", there is another one on the market that is 7/8".
My opinion is there there shouldn't be that much difference between them.
The stock one that you have, (1/4" or more likely 3/8") is not quite worthless, but you will notice a big difference if you get an upgraded bar.
You can buy the Sus Tech bars as a set (I did) and it is well worth the money.
Apr 16, 2020 05:15 AM
knight_yyz
Nov 1, 2015 01:34 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
