How realiable are Maximas?
Originally Posted by Madmax1991
Check out my Cardomain site by the link in my sig...
I added the 3rd maxima to my collection tonight 93 GXE 406k km's one owner, original engine and tran, and it's smooth as butter. I love maximas, very reliable, you just need at least one good hook up for used parts(ie the .org)
My moms Maxima has 235,000 on it. The original tranny (auto) lasted 233,000, with quite a few of those miles with me behind the wheel. So, yeah 3rd Gen Maximas are reliable. It's the car that got me hooked on Nissan.
1991 Maxima
Here are the some of the more substantial things I've replaced on my wife's Maxima:
83k T-Belt, H20 pump, Frnt Struts, All Brakes, Steering Rack, Tie-Rod Ends, All Filters, Outer CV-Joints
100k Spark plugs, Cap & Rotor
105k Driver's window regulator
110k Both Frnt Wheel Bearings, Both Ball-Joints, Pass Halfshaft, Shift-Rod Bushing
Things to note: Clock works intermittently, runs a little rough, paint holding up well, 26 mpg on highway, not as reliable as the Accord we sold to get this, not a reliable as my '89 Ford Taurus SHO either.
with the exception of the regulators and Shift-Rod Bushing, that is all normal on ANY car.
Bry593
Steering rack, ball joints, wheel bearings..... aw come on, you know this stuff shouldn't be toast at 100k.
Bry593
Bry593
Ball joints =way beyond normal
Wheel bearings = beyond normal.
Totally normal stuff
Seems pretty reliable and fun though plenty of little annoying problems that are not crucial.
I know some of these are covered in various threads, but if you have suggestions feel free to respond or PM.
I cannot normally repair stuff myself nor do I know much about cars in general.
98 SE
Digital dash board croaked; cannot see mileage, speed.
A/C croaked; it appears some circuit on dashboard is not functional.
Driver side door does not close so well because the door is hanging lower.
Auto tranny slips esp. from 1 to 2. but works with proper handling.
Cannot use Overdrive (low revolutions).
Back left window falls down and won't work (probably regulator as mentioned elsewhere).
Radio whines (I guess the capacitor problem)
No sound from Bose speakers; sometimes suddenly kick in and work.
Cassette player has very low sound; starts out semi ok then peters out.
Various electrical problems: high beams won't turn on, clock.
Driver side electrical lock does not work any more.
Axle boot problem (should I fix this?)
Vibration on the right front esp at high speeds; possibly related to brake change.
Broken antenna of course.
98 SE
Bry593
Bry593
As for ball joints and wheel bearings, aw c'mon. Dependent on your driving and road conditions, replacing ball joints and wheel bearing are pretty normal; Nothing out of the norm I'd say.
I don't think there is a milegae guarantee on suspension parts. Heck, I busted a left strut and some other suspension components on a drain hole on the Belt Parkway (NYC) about 2 weeks after I changed them.
98 SE
98 SE
Goffery2uned
Aug 21, 2015 09:50 PM
julian888
Aug 6, 2015 04:39 AM
