Having trouble pulling the halfshaft out...
Old Sep 19, 2003 | 09:32 AM
Goodbar6's Avatar
Hey,
i have a 90 5 speed, and im in the middle of pulling the drivers side halfshaft. I have everything done to pull it out, but it wont budge. Is there a trick to pulling it out?
Tyler
Old Sep 19, 2003 | 09:37 AM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
do you have an axel puller ? they are in pretty tight.
Old Sep 19, 2003 | 09:44 AM
Goodbar6's Avatar
no, i dont have an axle puller...are these readibly available?
Old Sep 19, 2003 | 09:58 AM
Goodbar6's Avatar
you know when they say "gently pry the halfshaft from the transaxle"? What they really mean is get the biggest freaking prybar you can find and lean on it somethin fierce! WOOOOHOO! Got gear oil in my hair though....freaking max is making me its *****.
Old Sep 19, 2003 | 10:17 AM
Matt93SE's Avatar
STFU n00b!
hehehe
use the axle as a slide hammer. push it all the way in, then jerk it out. after a few tries it'll usually come out.
getting the new one back in is the fun part!
Old Sep 19, 2003 | 10:33 AM
wawa92gxe's Avatar
Do as Matt said. It is very efficient!
After i messed with mine with some prybar according to what the book said, and got ****ed off,
then i dragged it out this way very quick.
Old Sep 19, 2003 | 11:45 AM
Goodbar6's Avatar
it went in fairly easily. I pushed it in untill it stopped, then jammed it farther untill it was all the way in.
Old Sep 19, 2003 | 12:56 PM
Matt93SE's Avatar
STFU n00b!
Many times I've had to use a 5lb dead-blow hammer to get them in. you got lucky. it all depends on how big that ring on the end of the axle is.
Old Sep 19, 2003 | 03:20 PM
subs1000w's Avatar
should you use the slide hammer method on the axle if you plan on reusing it or just if your replaceing it
HerpDerp1919
Sep 29, 2015 02:02 PM
zmcneely13
Sep 26, 2015 02:26 PM
