Rear Sway bar?? LOOSE
Sep 24, 2003 | 10:50 PM
my rear sway bar is messed up..the bolts that hold it in place are bent and let the sway bar loose on the driver side so it is not in on that side..i want to take it off casue i am worried that the other side will mess up and break while i am driving..is it bad not having a rear sway bar for like 2 months?
Sep 25, 2003 | 12:11 AM
why not get some more bolts?
Sep 25, 2003 | 09:44 AM
i want to get a new RSB..and at the same time the bolts....ohh and i drive once a week that is it to go home from school.
Sep 25, 2003 | 10:16 AM
yeah I had similiar problems too, the end of your sway bar where it joints the spindle are bolted together via a rubber bushing. The rubber bushing can be royal pain, espcially if it gotten beaten up. Replacing the bushings alone is royal pain since no one are make the brushings in the states. However, noltec.com.au is making them and they're in Australia. Their prices for these stupid bushings cost about $90 shipped so you might as well buying a new bar such as ST and it still equiped with polyuranthe brushes.
So to answer your question, just make sure to slow down while making turns or you could lose balance and the car could easily tilt over and freak you out. Don't worry it happened to me all of the time when I first got the car. When you got some times and moneys, make sure you get that bar replaced NOT fixed. The rear ends replacement is a piece of cake, shouldn't takes no more than 30 mins but paying for it is not fun.
Quote: my rear sway bar is messed up..the bolts that hold it in place are bent and let the sway bar loose on the driver side so it is not in on that side..i want to take it off casue i am worried that the other side will mess up and break while i am driving..is it bad not having a rear sway bar for like 2 months?
Sep 25, 2003 | 11:46 AM
thanks for the info
