Converter taking awhile to lock up when on the highway
Old Sep 29, 2003 | 11:48 AM
Penz's Avatar
Lately, if my car sits longer for more then a couple hours, the converter on my car does want to lock up. I will drive thru town for a few minutes and then hop on the highway. It takes another 3 mintues while crusing at 70 for it to lock up.
what could be the problem?
Also, my car hesitates when giving it gas from a shop. Maintence parts have all been replaced within the past 15k.
Old Sep 29, 2003 | 12:13 PM
rcy's Avatar
rcy
Regarding the torque converter - has it recently become cold where you live? I know it will not engage until the tranny fluid has warmed up.
Old Sep 29, 2003 | 12:41 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
is this the original converter.?
Old Sep 29, 2003 | 02:08 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
when you say hesitates from a stop...do you mean the RPMs rise and the car barely moves or its just sluggish off the line?? RCY is right about the temp thing, but the sluggish starts combined with the intermitent lock out could mean the inevitbale tranny rebuild is in the future
Old Sep 29, 2003 | 02:52 PM
CandiMan's Avatar
Say Candyman 5 times
Are you sure it's lock-up you are refering to? Could it be possible you are refering to the trans not going into 4th gear? When the trans goes into lock-up if you're not paying attention you can hardly tell, but you will definately know when it's not going into 4th gear. Regardless there are several conditions that can effect the trans not going into 4th or lock-up, without quoting me a few I can think of are trans temp (as previously stated) throttle position, shift selector position, O/D switch, etc.
Old Sep 29, 2003 | 03:19 PM
chchmax's Avatar
I noticed the T/C lockup took longer to engage over the winter here than in summer. Usually it went straight in while on the highway, but over winter it took nearly 5 mins to engage! Btw, i got a new tranny and T/C about 25k ago, so pretty sure its normal.
So, i agree with rcy. The fluid just needs to warm up. Although, have you checked the level / condition of the tranny fluid lately?
As far as the hesitation goes, could be any number of causes.. Can you be more specific as to which maintenance parts you've replaced? and if there's anything you've done to the car recently around the time you noticed the hesitation?
Old Sep 29, 2003 | 04:40 PM
Penz's Avatar
Thanks for the help so far.
it is the original converter and tranny. Also, it has been getting colder out so I guess it is just a temp issue and the tranny needs to warmup.
the hesitation just makes it sluggish off the line. Maintence includes cap, rotor, wires, plugs, fuel/air filter, pcv valve, and I also added some fuel system cleaner a couple weeks ago.
The hestiation started about 3k ago and around the time it started I didn't touch anything on the motor. It was just out of the blue when it started.
Old Sep 29, 2003 | 08:00 PM
subs1000w's Avatar
i would check fuel injectors next. one of them could be bad and make it slow off the line if ones bad you should be able to here a miss in the exhaust and feal a slite vibration at idle and how many miles are on your car the tranny may need to be rebiult soon
Old Sep 29, 2003 | 08:52 PM
Penz's Avatar
it does have a vibration at idle. It was hardly noticable when I bought the car. I bought it with 127k and now it has 133k.
I hope the tranny doesn't go out soon but then again the last guy drove it with about a quart too much in the tranny. I changed it and it didn't make any difference in shifting nor did it smell burnt.
captchaos
Mar 15, 2016 12:18 PM
f.matejaiii
Sep 21, 2015 12:09 PM
97_GXE
Sep 15, 2015 06:47 AM
Bonka
Sep 14, 2015 11:18 PM
carid
Sep 9, 2015 05:06 AM
