Somethings not right...
Old Oct 8, 2003 | 08:25 PM
JennyDu_69's Avatar
I have a 1994 automatic. Now this is technically my first car and Im already having problems. When I have my AC on everything is great. Im freezing inside of a minute and there are no weird noises going on, but my problem is whenever i push on the accelerater to go my car dies. Ive been told its my altenator and its not, I got that checked out. Also Ive been told its my compressor but I find that hard to believe. The problem is I dont have alot of money to figure this out and I need help!
Old Oct 9, 2003 | 06:54 AM
subs1000w's Avatar
that sounds like an electrical problem id take off your AC belt and then turn on the ac and if it still dies its an eletrical problem if its fine then you ac compressor is out
Old Oct 9, 2003 | 08:13 AM
JennyDu_69's Avatar
My uncle works on cars alittle and he said it could be the kill switch. Does that sound like it may be the problem?
Old Oct 9, 2003 | 09:17 AM
internetautomar's Avatar
mod or sell?
how does the car run without the A/c running?
Does it stumble at some point in the pedal travel?
Old Oct 9, 2003 | 10:05 AM
JennyDu_69's Avatar
No it runs perfectly fine. It even runs fine with the AC on until you try to go from a complete stop.
Old Oct 9, 2003 | 03:18 PM
LittlePiggie's Avatar
does it idle fine at a stand still?
Old Oct 9, 2003 | 03:30 PM
Jeff92se's Avatar
I'm needing a caw
Does the idle go up when you turn on the AC? If not, then the idle is probably going down too much because of the extra load. The ECU is supposed to up the idle speed when the AC is on to prevent the idle from going too low.
Old Oct 10, 2003 | 10:07 AM
JennyDu_69's Avatar
If I remember correctly the idle is just fine. Has anyones '94 done this to them before? Thanks for all the advice Ive gotten so far though...
Old Oct 10, 2003 | 10:11 AM
Jeff92se's Avatar
I'm needing a caw
What do mean "just fine". Does the idle speed go up when you engage the AC or not? What does the idle speed go up to??
Old Oct 10, 2003 | 10:15 AM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
mine hasnt done that to me yet but mines a 93. however theres no real difference. sounds to me like what the other poster said. the scu is supposed to compensate for the ac. so when you put in in drive and strain the motor even more it dies.
Old Oct 10, 2003 | 10:16 AM
JennyDu_69's Avatar
It speeds up but im not sure to how much, I will have to check it out.
Old Oct 10, 2003 | 10:17 AM
JennyDu_69's Avatar
Well I suppose I could go and get the ECU checked out. I was wondering if a simple diagnostic could maybe tell me whats wrong.
Old Oct 10, 2003 | 10:20 AM
Jeff92se's Avatar
I'm needing a caw
It's probably not the ecu. It's probably a relay/switch etc.
Old Oct 10, 2003 | 10:21 AM
JennyDu_69's Avatar
Such as the kill switch for the AC?
Old Oct 10, 2003 | 10:25 AM
Jeff92se's Avatar
I'm needing a caw
Lower left. But maybe that's for the unit itself and not for the high idle switch
Old Oct 10, 2003 | 10:28 AM
JennyDu_69's Avatar
It never fails to amaze me how much you try to learn about cars and your still lost!
Old Oct 11, 2003 | 10:34 PM
JennyDu_69's Avatar
Ok new information, I turned on my car today and without the AC on it idled out to a perfect 500 rpms, but when I turned on my AC it dropped to a good 250 rpms. So anyone knows what that means?
Old Oct 11, 2003 | 11:13 PM
Bman's Avatar
Isn't 500 rpm already on the low side? Most automatics tend to idle around 750-ish don't they?
There's definitely something wrong here...
Old Oct 11, 2003 | 11:25 PM
Logan91VE's Avatar
yep sounds like the idle is too low when the AC is on, so when you put your foot down it just stalls. im not sure on the fix, some else will have to help there.
Old Oct 11, 2003 | 11:42 PM
Jeff92se's Avatar
I'm needing a caw
It means that the switch/solenoid or relay that tells the ecu to up the idle speed is not working.
Old Oct 11, 2003 | 11:48 PM
mtcookson's Avatar
with the ac off it should idle at 750. that definately needs to be fixed as well.
Old Oct 12, 2003 | 06:04 PM
JennyDu_69's Avatar
Is there any way to test any of those things myself without actually having to go and get them checked out?
Old Oct 13, 2003 | 09:53 PM
JennyDu_69's Avatar
Ok so exactly how do I fix the idling problem in the first place?
Old Oct 14, 2003 | 12:21 PM
JennyDu_69's Avatar
Ok new information, I went to Midas because I have some friends who work there and they thought it was my idle censor but come to find out its my compressor. If I had a choice it would be the censor because it only costs about $300 to fix but I bought a book on my car and im going to see if maybe I could get my b/f to fix it for me if I get the parts. Do you think that its a good possibility?
tarun900
19
Dec 20, 2021 06:57 PM
leatherneck
Sep 30, 2015 09:16 PM
dshinn
Sep 26, 2015 08:07 PM
