Ok, I hope sumbody has theses!!!!!
Old Oct 13, 2003 | 10:18 PM
EdzMax's Avatar
Hey guys, sum of u guys will remember my problem with getting a FTSB. My pump housing for my brakes gets in the way for 1, so I'm getting a guy to make me one from scratch!! Well, what I really need is the measurements for the couples that go on the strut & how far the holes are from each other. & also the bar itself. If u guys dont know what I mean, I do have a pic of my problem. So, any suggetsions would be really appreciated
Old Oct 13, 2003 | 10:30 PM
EdzMax's Avatar
By the way, go to my site & page 6 has what my problem is.
Old Oct 13, 2003 | 10:31 PM
davebond007's Avatar
Would a VE strut brace fit?
Wait nevermind. Just looked at your pictures.
Old Oct 13, 2003 | 10:37 PM
nubiannupe's Avatar
OG Maxima.org Member
If nobody else gets it, I'll get the measurements from MY FSTB in the morning and post 'em. The bar might be different since I have a VE and you have a VG, but that should at least put you in the ballpark.
Old Oct 13, 2003 | 10:40 PM
MrGone's Avatar
hmmm, I think your best bet would be to ask the guys here:
http://forums.max-world.org/index.php?showforum=81
or the international forum here:
http://forums.maxima.org/forumdisplay.php?f=73
Old Oct 13, 2003 | 10:41 PM
EdzMax's Avatar
I guess the main thing I would need is the bar where the bolts go too. I am going to have it sorta curve out to go around the pump housing. As far as the bar, the guy will make from scratch too, but the measurements for that will be good to. Thanks very much for that. I hope I can return the favour if this works for me
Old Oct 13, 2003 | 10:45 PM
EdzMax's Avatar
I will have to make mine up from scratch, so I have to get the measurements. Have u seen my problem on my site, page 6???
Old Oct 14, 2003 | 06:39 AM
internetautomar's Avatar
mod or sell?
I just looked at you pic on pg6 and have you checked to see if anyone has a FSTB that has the bar mounted to the front part of the loop?
(did that make any sense?)
From the pic at least it looks like that would solve your problem
Old Oct 14, 2003 | 06:50 AM
Michael's Avatar
Back in a 3rd Gen.
have you tried a FSTB? I really do not see a problem here because I have 2 bars and both of them have the bracket go on the front side (toward the front of the car) of the middle bolt of the strut. That is far enough out to clear your brake booster/master cylinder according to your pics.
The Max has a FSTB on his maybe you should pm him and see what he says. His is an aussie max so the configuration is probably the same.
EDIT: I was just looking at a pic of his FSTB and it appears the bracket is farther toward the front than mine are so maybe he got a special one or had it made.
The easiest thing to do would be to get a cheap bar and cut the bracket off where the bar mounts and just re weld it farther toward the front of the car. THat would be easier and cheaper than getting one custom made
Old Oct 14, 2003 | 07:24 AM
chavez's Avatar
I got a FSTB off chris smalley a few months back for my maxxie, the only problem i had was the hose... moved the hose aside (you know that hose that is attached to that bracket near the nut) and problem solved.
It's an eBay FSTB...
I did a write up on how to install one after i got it...
Check out the piccies in the article...
http://www.freakgamer.com/cms_view_article.php?aid=12
Old Oct 14, 2003 | 07:57 AM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
diddnt realize the wheel was on the wrong side (at least here) cause the 2001 FTSB vits mine but i have a VE. And they make on for the VG here. However i see your issue that stinks.
Old Oct 14, 2003 | 07:05 PM
EdzMax's Avatar
Hey awsm66, do u have pics of that job? U do know the problem I'm having. My cylinder is pushed too far up from the factory! I can't change that, so I have to probably try the way u said.
Hey chavez, ure bar wont fit either.
Hey
Old Oct 14, 2003 | 07:11 PM
EdzMax's Avatar
I got a pic from davebond & hes got a pic of a 200sx, but this is the bar I need! Can anybody find out with is this one:[/QUOTE]
Old Oct 14, 2003 | 07:14 PM
EdzMax's Avatar
Just had a look, this IS the bar I can use!
Old Oct 14, 2003 | 08:20 PM
|Bijan|'s Avatar
UCF Lexus
cool EGT sensor
Old Oct 14, 2003 | 09:08 PM
Michael's Avatar
Back in a 3rd Gen.
Hey
Sorry I do not want to post someone elses pictures. He may not want it posted. Email or PM him (The Max) and he will probably help you out.
and I see the problem you are having...thats why I said email or PM him...because he is RHD too and has a fstb.
good luck...hopefully you can either have one re welded or custom made.
Old Oct 14, 2003 | 09:09 PM
Yeah, thats a 200sx/sentra strut brace. That picture is of a b14 200sx (basically a sentra).
Here's an ebay auction with it for sale:
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2437319632
You may not be able to use the bar that goes across, but you certainly can use the mounting brackets (and I think they are the same as a maxima, just not as far apart since the car is narrower).
So you just use the brackets from the 200sx bar and the actual bar from your maxima brace.
HTH.
Old Oct 14, 2003 | 09:13 PM
(I also resized the picture that Edz posted here to cut download time and make the forum look a bit better).
Old Oct 14, 2003 | 09:56 PM
EdzMax's Avatar
Hey dave, thanks for that. I will see if I can get one from here.
Old Oct 15, 2003 | 03:07 AM
chavez's Avatar
Hey edz that just sucks that a standard FSTB doesn't fit...
How the max going anyway?
Old Oct 15, 2003 | 03:56 AM
chchmax's Avatar
yeah, that sucks eddie! mine's the same as the yankee ones.. come say hi in the international forum!
Scott
Old Oct 15, 2003 | 10:46 PM
EdzMax's Avatar
Hey chavez, max is going great. Gotta save up sum money so I can get a new y-pipe. Hows ure max going?
Old Oct 15, 2003 | 10:47 PM
EdzMax's Avatar
Scott
Hey Scott, will do that!
Old Oct 16, 2003 | 06:07 AM
chavez's Avatar
Probably selling it....
see this post
The max had a good run but i'm wanting a faster car... maxima too cruisy... lol and i want a stick shift! and they don't sell max's with a stick down here
Old Oct 17, 2003 | 01:51 AM
EdzMax's Avatar
see this post
Yeah, I know about auto maxis. Well, when I have to get a new trans., going to get a 5-speed instead. Guy told me its going to be the same as getting a second hand trans. Man, read the thread about ure max, that sucks BIG time. Hey, can I have the FTSB?
Old Oct 17, 2003 | 02:44 AM
chavez's Avatar
I'll get back to you on the FSTB... but if you want it I'll sell it to ya... I won't be selling my car till around november, so any aftermarket parts that I can take out... I'll take them out (Will need to find a stock air box.....), and sell it (except for the K&N pod coz i can put that in my new car).
Probably looking at $AU60 + shipping for the FSTB (I only got it a couple of months back).
Mar 12, 2020 12:06 AM
0m3nc0w
Sep 11, 2015 05:21 PM
16_SR
Sep 9, 2015 07:14 PM
TheMafia
Sep 4, 2015 08:26 AM
