tranny 90 maxima
Old Oct 17, 2003 | 08:36 PM
scott jacobson's Avatar
tranny 90 maxima
just bought 90 maxima with bad auto trans slips in1st 2sd 3rd. reverse seems ok is the transmission shot or is it something that can be fixed easily .Also any suggestions on removing the tranny or getting it fixed.
Old Oct 19, 2003 | 01:13 AM
abunai's Avatar
Shop around for price, and have it rebuilt.
If you know how to replace it yourself, someone is selling rebuilt trans on ebay.
Old Oct 19, 2003 | 12:14 PM
broncoguy's Avatar
You might want to have the fluid flushed first, to see if that helps. Chances are if it's already slipping, the flush won't help, but if it does, you won't have to spend the money. Also, do a search. There's a ton of info on auto trannys on this site.
Old Oct 19, 2003 | 07:31 PM
internetautomar's Avatar
mod or sell?
as long as ur replacing the trans Y not do a stick swap?
Old Oct 19, 2003 | 08:13 PM
subs1000w's Avatar
i like the last idea alot
Old Oct 20, 2003 | 01:09 PM
abunai's Avatar
Try a bottle of Lucas trans fix. Might help.
Old Oct 20, 2003 | 01:34 PM
mod or sell?
LUCAS TRANSMISSION FIX contains no solvents or anything else that would be harmful to an automatic transmission. It is a thermal stable blend of petroleum extracted additives designed to correct existing problems and prevent new ones in automatic transmissions.
LUCAS TRANSMISSION FIX stops slip, hesitation and rough shifting in worn transmissions. It completely eliminates most seal leaks, lowers operating temperatures, and stops foaming in hard working units. A must for motor homes and commercial vehicles. LUCAS TRANSMISSION FIX is excellent for preventative maintenance and will extend your fluid life up to four times longer. It will also extend needed protection to planetary gears.
One 24 ounce bottle of LUCAS TRANSMISSION FIX can be added to existing fluid (a moderate overfill is not harmful). A second bottle may be necessary in large or badly worn transmissions
ALSO known as transmission in a bottle
Old Oct 20, 2003 | 03:09 PM
maxima 90 tranny
is tere any bands that can be adjusted in a re4f02a tranny ???
Old Oct 20, 2003 | 11:01 PM
abunai's Avatar
I had a Maxima that, when cold, took about 30 seconds to go into drive. One whole bottle of Lucas and a day of driving solved the problem. Good stuff.
There is a band you can adjust. I suggest you check in a factory service manual to find the correct adjustment.
Old Oct 21, 2003 | 06:30 PM
90maima tranny
where can a guy get a service manual i bought a haynes manual not jack in it about trannys
Old Oct 21, 2003 | 06:37 PM
also isaw i may need a socket to take out axels ???
Old Oct 22, 2003 | 01:33 PM
abunai's Avatar
Factory service manual is kind of expensive. Only the dealer has them. You can sometimes fine them on ebay or used book store. Put a post on this site, I'm sure someone will help.
I think the socket was a 32mm, but I could be wrong. Good to have one as the boots are always spliting.
Old Oct 22, 2003 | 03:19 PM
jaguax's Avatar
Because it's a VG it's not worth it
Old Oct 22, 2003 | 04:33 PM
mod or sell?
that would make it unique
Old Oct 22, 2003 | 04:51 PM
89maxSE's Avatar
Hey now, I have a VG stick. Whats wrong with that? :-)
Old Oct 22, 2003 | 05:13 PM
jaguax's Avatar
I meant more along the lines of going through the trouble and spending the money to convert your auto vg to a manual. Might as well save the money for a bit and buy a 5 speed SE.
Lakersallday24
Jun 16, 2019 01:35 AM
rtirbany
Sep 8, 2015 11:46 AM
Supragte
Aug 12, 2015 10:00 PM
Derrick2k2SE
Aug 12, 2015 06:47 PM
Tanvirkamal
Aug 5, 2015 01:32 AM
