smoke from under hood (pic)
Old Oct 20, 2003 | 03:03 PM
CanadianMaxima's Avatar
hey guys,
just yesterday i noticed thatr when i was stopped at a red light smoke was coming up from under the hood. its regular grey smoke. i've had a burning smell in the cabin for a while but this is the first time i've noticed the smoke. tell me if the pic isn't clear enough. thanks
[IMG]http://images.cardomain.com/member_images/1/web/373000-
373999/373484_2_full.jpg[/IMG]
Old Oct 20, 2003 | 03:04 PM
here is the link
http://images.cardomain.com/member_i...484_2_full.jpg
Old Oct 20, 2003 | 04:59 PM
shavedmax's Avatar
if it is comming from the front of the engine on the trans side then it is probably comming from a bracket under the o2 valve. i had that, tightened it up, all good now
Old Oct 20, 2003 | 07:06 PM
MrGone's Avatar
I'm thinking broken Exhaust stud.
on a side note: I had 'smoke' coming out from under my hood today aswell. Lots and lots of rain + no splash gaurds. I should probably find the bolts to install those splash gaurds
Old Oct 20, 2003 | 08:06 PM
cneary812's Avatar
Splash guards bad... leave them off makes for less weight!!
Old Oct 20, 2003 | 08:10 PM
MrGone's Avatar
VE power. few extra pounds isnt going to make it any slower
Old Oct 20, 2003 | 09:07 PM
its not really on the trans side. its coming from right next to the oil dip stick. also, if its exhaust studs would it be smoking all the time or just after i start the engine. cause the smoke never stops. i'll try looking for a bolt to tighten tommorrow morning
Old Oct 21, 2003 | 09:33 PM
valky's Avatar
Is your valve cover gasket leaking? Oil leaking onto the exhaust manifold will smoke as soon as the exhaust manifolds get hot.
Old Oct 22, 2003 | 10:21 AM
89sks's Avatar
Take a phillips screwdriver and tighten down the screws to the valve covers. Actually Im not sure how the VE valve cover is attached but I bet the screws or bolts are loose or you have a leak in the gasket. That's what was wrong with my VG.
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
BobTX10
Oct 7, 2015 08:43 AM
bigfrank
Oct 1, 2015 12:51 PM
leatherneck
Sep 30, 2015 09:16 PM
