!Bad engine problems, please help me ORG!
Old Oct 26, 2003 | 04:44 PM
92SE_Threat's Avatar
OK guys, first let me say that it drove normal last night, and Id say the only thing that could of happened was something rain related Id imagine cause thats all that happened to the max while she was parked. Anyways, so I start her up, and she is idling very rough, vibrations are relative to the RPM, at about 1K and 3K+, smooth as a babys butt through 2K. I can hear it putting out the muffler too. I pop the hood and feel around on the valve cover and can feel a little vibration going on. I let her warm up before testing the RPM's and she still did it. Any ideas guys? something wet? I have work tomorrow and im praying that its just a temporary thing. please post up if you have any clues...
Old Oct 26, 2003 | 04:55 PM
internetautomar's Avatar
mod or sell?
If your car had a cap I'd say you had a cracked cap. But since you don't I'd suggest disconnecting the coils 1 at a time and see if 1 of the coils doesn't cause a change if you find 1 that doesn't remove the coil and look for cracks.
Just my OP
Old Oct 26, 2003 | 05:00 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
i agree there it sounds like one of your coil packs went bad.
subs1000w's Avatar
check the injectors also. 1 bad injector would make it idle rough also
Old Oct 26, 2003 | 05:30 PM
Well that sounds good but the fact is I am a n00b at the car stuff, and I dont know how to do any of that. First off, why would any of that stuff happen over night? And also, is it possible that this is a wet problems that might dry out and be working fine the next day? If this is a problem that I cant fix, I'm gonna have to take it in, so I wanna know what to ask them...
Old Oct 26, 2003 | 06:10 PM
mod or sell?
1.Look at your engine
2.See the 3 round things in the middle of the front Valve cover?
Each one of those is a coil for a front cylinder.
3. See the 3 round things in the intake towards the back of the engine?
Each one of those is a coil for a rear cylinder.
4. One by one disconnect the electrical harness from each one.
IMPORTANT! oNLY DISCONNECT ONE AT A TIME DO NOT HAVE MORE THAN ONE DISCONNECTED AT ANY TIME
5. Now you have hopefully found no change when you disconnected one of the coils but you DID see a change when the rest of them were disconnected.
The one that DIDN'T cause the change is the cylinder that is causing the problem.
Then it will either be a coil or an injector.
To check either one check the stickies for the chilton with testing specs
Old Oct 26, 2003 | 08:23 PM
do this while the car is running?
Old Oct 26, 2003 | 08:51 PM
mod or sell?
Oh yeah I should have said that
Old Oct 26, 2003 | 08:55 PM
what about the MAF?, i was thinking about that...
Old Oct 26, 2003 | 09:00 PM
mod or sell?
What is it with people and trying to blame MAFS?
I sell 10x more injectors than I do MAFS which is still way more than I sell of coils. Actually I can't remember the last time someone asked me for a VE coil.
Nissans side feed injector is a garbage design so it tends to have a higher than normal failure rate. Most injectors plug up with gunk. The nissan just burns out.
Old Oct 26, 2003 | 10:45 PM
OneBAdSE's Avatar
did you ever over rev your car? possibly through a lifter out of prime? if so chances are it will go back in prime itself just have to wait.. if its even drivable. somthin similar happened to me and it just went away.
Old Oct 26, 2003 | 10:47 PM
mtcookson's Avatar
can't over rev these engines. they have a fuel cut rev limiter. (unless of course you are going 100 mph and drop it into 2nd)
Old Oct 26, 2003 | 10:56 PM
Spipedong90's Avatar
I would check the coils, and if you have a good friend with a max, borrow theirs and check.
I should refrain from too much comment, because I can unplug all 3 front coils without affecting my engine.
Old Oct 26, 2003 | 11:08 PM
OneBAdSE's Avatar
you cant over rev? punching it in first up to lets say 5300rpm an missing 2nd.. it wont over rev?
Old Oct 26, 2003 | 11:10 PM
OneBAdSE's Avatar
btw, not trying to take the thread off topic, even tho i through in an idea cuz it sounds like u have the same problem that happened to me. but anyone with a fast VG, i would like to talk to u cuz i wanna get mine running pretty good, thanks.
mtcookson's Avatar
no, the ecu will cut the fuel at a certain rpm so it won't rev any higher. the only way to get it to over rev would be to, like i said, be driving fast and accidentally shift into a lower gear instead of a higher gear forcing the engine into a high rpm. and besides, i know the vg's are good for 7000 rpm. i'm sure the ve's can take that much or higher so it would be pretty hard to over rev these things.
Old Oct 26, 2003 | 11:17 PM
MrGone's Avatar
OneBAdSE, click here for all the answers to your question.
Old Oct 27, 2003 | 06:21 AM
OK, so we are basically all agreeing that its either ignition or lifters?
Old Oct 27, 2003 | 06:25 AM
subs1000w's Avatar
i still think injectors and i dont beileve a lifter would make your car miss
Old Oct 27, 2003 | 06:27 AM
OK, I dunno how to check injectors, but i suppose the answer is in the search, if not ill ask...
Old Oct 27, 2003 | 08:10 AM
subs1000w's Avatar
if you keep unplugging the coils till your engine speed dont drop then youve found the cylinder thats giving you your problem. Once youve found it turn the car off and swap coil packs with an ajacent cylinder, then turn the car back on and check to see if the same cylinder is still not firing if its working now "when you unplug it the engine speed drops" your coils bad if its still the same your injectors bad
Old Oct 27, 2003 | 07:00 PM
sorry if i am being annoying or newbed but, there are no other options, coils or injectors? That would be great, I thought it would be much more serious. Ill go check that stuff out tomorrow hopefully...
vingodine
45
May 21, 2016 12:46 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Samedi
Aug 13, 2015 04:05 PM
